Question about Whirlpool Refrigerators
Whirlpool FRSS2VAF20/0 brought this item as graded working great had it 3 months but only just connected to water supply .water dispenser is a trickle and there is no ice am i doing something wrong ?help !! do i need i filter??
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 619 Answers
SOURCE: whirlpool ice dispenser not working
motor drive shut down/reset if their is available
Posted on Dec 31, 2007
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Posted on Mar 11, 2009
I have a whirlpool refrigerator Model GI5SVAXVL01. (2 door upper- Freezer on bottom). SN K01668079 About once a week there is a puddle of water on the floor right front side of refrig. I cannot tell where...
After looking carefully at the exploded views of this refridgerator
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GI5SVAXVL01/1198/0161000?pathTaken=&prst=0&shdMod=GI5SVAXVL01
I believe your problem is caused by a leaking hose or fitting for the water dispenser
Pay close attention to items # 11 and 19 on the diagram labeled Refridgerator door parts
Try turning off the water supply to the dispenser and see if the problem is resoleved... if so you know thats where the problem is
Jan 21, 2011 | Whirlpool Refrigerators
Water dispenser hose broken
Hi;
you would have to remove the door(and front kick panel) turn water & power supply off first. Unclip water lines and electrical connector on top of fridge. You will require food grade water pipe 6-8mm, this will slide thru the hole, have patients when doing this
Jul 06, 2010 | Whirlpool GC5THGXL Side by Side...
The water from my water dispenser isn't cold.
Hi, Only thing you can do is check the temperature in the fresh food section and it should read 34-27 degrees. The temperature controls should both be set at half of the #'s on the dial.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Whirlpool GD2SHGX Refrigerator
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Water dispenser no longer works.
Where the water supply connects to the Ref there is one water valve but, two solenoids. One for the water and one for the ice maker. An OHM meter will tell you if these solenoids are good.
Solenoids good;
Set the meter to volts and check if power is getting to the water solenoid while pressing the water despensor. No power, bad switch.
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Dispenser on Side by Side not dispensing
It's quite possible it is plugged by hard water deposits forming in the supply line as these lines are quite small. You can check if it is plugged by shutting off the supply line and removing it. After removal turn it back on but have the end in a bucket in case the blockage is in your fridge unit. If water comes out it is in the fridge. Usually there is a screen to prevent large particles from entering. Make sure that is clean. Try these and see if that helps. If it doesn't get back to me as the trouble shooting will get more intense. I'm hoping this helps.
Sep 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Water only dribbles from the water dispenser
It sounds like you have a clog. If the clog is at the nozzle, you would still have pressure, however nothing would come out. It could also be the valve that opens for the dispenser.
Take it apart and look. I would focus on the dispenser end.
Dec 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
171 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
