Question about Dell Dimension 4600 PC Desktop
Dead Dell My Dell computer is plugged into a power strip along with my peripherals, printer, etc. After an electrical thunderstorm a couple of days ago, the computer will not power on, but everything else on the powerstrip will. I've tried plugging it straight into the wall socket but that didn't work either. Is there something else I could try?? What could be the problem??
  • nsindian
    nsindian May 11, 2010
    Have you tried a totally different wall outlet than the original location?
  • 3,940 Answers
If you had a modem in the system and it was connected to the phone line during the storm, remove the modem from the system and see if the system will post.
Modems and thunderstorms are a bad mix
Posted on Jun 13, 2008
  • 29 Answers
Try wiggling the power cord or reseating it. but if you have tried plugging it in directly and it still doesnt work. i guess its time to call dell tech man for a replacement.
    Novelist:
    Champion:
  • 254 Answers
It is likely the power supply has suffered damage, or has just plain failed. Dell did have problems with certain power supplies in models such as the GX270, probably others too.
Anyway, if you have a voltmeter, you can check for the presence of voltages. Modern computer power supplies have a standby and main sections. I'd guess the standby portion is dead, and if so, your computer won't turn on at all. Here is a site listing the pinout & voltage spec for a typical ATX power supply: http://pinouts.ru/Power/atxpower_pinout.shtml
Note the standby line- again, this voltage will be present anytime the computer is plugged in. The main section of the power supply comes on when the power button is pressed.
If you tech savvy, you could try repairing the power supply if not toasted severely. Otherwise, a standard universal replacement might fit the bill, or just call Dell for an exact unit.
Why isn't the AR06 not allowing my PC to power down?
BIOS features vary across manufacturers, etc. There may be a feature in your BIOS which is along the lines of "Power On after power failure." This "feature" started to be added when soft switches were added to computers. It's designed so that when your computer loses power, it will come back on the next time power is at the plug so-to-speak.
Also, the ecoficient outlet may not be compatible and/or have some inconsistent operation with some power supplies within some computers. I'm familiar with this type of energy saving outlet/power strip, but not the intricacies of the brand, etc.
Aug 21, 2014 | Computers & Internet
I have a Dimension 5100. There was a big thunderstorm about a week ago and our power was out for maybe 4 hours. Now, the computer will not turn on. It, along with the monitor, printer, router, etc. are...
you mostlikely blew a fuse in your power supply, either that or your cord became damaged, to check the cord, plug it into another computer or a monitor, 99% use the same type of cable, if it is your power supply, you need to remove the ps from the desktop, obviously while unplugged and undo the screws for the ps casing, then simply remove the old fuse and replace it
Aug 27, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
I need to connect a 34oo series lexmark printer to a dell comp. xp
Not sure how much I can help you.
*Turn computer off.
*Plug printer into a port on the back of your computer. There are very few ports so you should be able to find one that makes your printer plug. Plug printer into power strip/outlet.
*Turn computer back on.
*Keep printer off for now. During installation it should tell you to turn the printer on.
*Put the CD that came with the printer into the cd/dvd drive. A menu should appear. You want to "Install" or "Setup" your printer. Something along those lines. Follow the instruction from there.
*After successful installation of the printer restart the computer.
That is as basic as I can make it. I hope this helps.
Thanks.
Jun 14, 2010 | Dell XPS 730 Desktop Computer
After power outage the printer won't power up.
The printer is dead, the surge got thru and fried it. Replace it and the surge-protector.
May 08, 2010 | Dell 922 All-In-One InkJet Printer
First it would not print anything in color. It put out a blank piece of paper. Then the whole thing froze up. I can not turn it off or on and the bar that moves along to scan the image has stopped in the...
Have you recently had a severe thunderstorm?
Sound to me the units components have taken a shock.
You can try to unplugged it overnight and turn it back on.Remember that if you run through a power strip and there is lightning and it intercepts the surge it has lost much of its protection!
Also only use the software or the actual printers power button to start or turn it off.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
COMPAQ Presario v6000 dead, Period
Hi there.
Remove the battery and try it on AC power only, if it boots up turn it back off and put the battery back in again and power it up again, if it boots up, the cause will have a small surge from the power strip caused by the thunder storm.
Good luck and thanks for using Fixya!!
Feb 27, 2009 | Dell Latitude L400 Notebook
Dell 922 printer jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Can a tv ordvd player be fixed after going dead after a thunderstorm
Not usually. If the thunderstorm damaged it, there is most likely all kinds of burnt circuits. Most warranties don't cover that kind of damag either, unless it was plugged into a power strip of some kind that has a gaurrantee against damage.
Jul 10, 2008 | Televison & Video
Dell Dimension 4600 PC Desktop Logo
82 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
