Question about HP PSC 2210 All-In-One InkJet Printer
Scanner where do i connect the wire for the all in one printer,scanner and photocopier hppsc2110 to the back of the processer
  • 37 Answers
How do l unlock scanner the printer is no longer photocopying
There is usually a manual sliding switch to rear of machine that is used to lock scanner head for transportation.see if it has been switched to the padlock symbol.
Jan 24, 2015 | Office Equipment & Supplies
Red light start button
the problem may be the scanner are you able to scan to pc or email/fax from the machine glass/
when the machine initializes are there any faults displayed ( the printer will continue to function even if the scanner fails) usually the error code 30.01.02 or something like that will be displayed-
the scanner is connected via 1 large connector found to the rear of the machine - does the cable look damaged in any way- is the connection 'good' has the grounding wire worked loose, if after these have been checked there is still no scanner then you may need either a scanner or main PCA/formatter fot the printer.
Belmonte business are able to help with the repair of this unit should it be required and would be subject to the usual costs.
available on 0161 480 5556
Dec 31, 2013 | HP LaserJet 4345mfp Printer
When hp photosmart does not photocopy what is that thing that can cause it not to copy
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now take a test print and CALIBRATE the scanner with the test print.
Now the printer must be set to copy if not there are errors on the scanner section.
Nov 15, 2011 | Office Equipment & Supplies
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
Canon IR scan problem
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
May 27, 2009 | Canon imageRUNNER 2200
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
All in one printer, scanner and photocopier wont work?
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Epson Stylus RX425 Multifunction...
Photocopies are very faint on one side
The scanner mirrors are dirty.
You can try doing a shading adjustment . You press menu #1934 to enter tech mode. Then in menus under maintenance go to shading adjustment, place 5 sheets of paper on the glass and run the shading adjustment. That may help.
But the problem is the mirrors are hazy and in need of cleaning. The rear, both side covers must be removed. Then 2 screws on the back of the scanner must be removed , and the connectors unpluged from the main board. There is also one green ground wire that is attached to the frame from the scanner.
Once the scanner is removed, you have I believe 4 screws to remove and the controle panel.
You have to be very careful opening the scan head under the lamp. It is just held together with plastic tabs. Under the lamp are the mirror and lens, that must be cleaned to get your copy quality back to mormal
Apr 01, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
Sep 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
