Question about Lanier UNKNOWN
My laptop running in windows 7 hang several times
  • 38 Answers
This can be helpful to you.
step 1. Click on 'start' than click 'computer'.
step 2. right click your windows installation drive (usually 'c' drive)
step 3. select 'properties'
step 4. click on 'tools' tab then click on 'check now' under the error checking option.
step 5. select both the option given ( "automatically fix file system error" and "scan for and
attempt recovery of bad sectors"). now click on 'start' .
step 6. you will be prompt to " schedule disk check". click it and restart your system.
Now windows will start checking your disk for errors n fix it automatically.
we recommends that you should do periodically (once a week) for better performance of your system.
Posted on Nov 03, 2010
My laptop hangs when i open a progamme and see movie, my laptop is Dell vostro 1088, i installed new version of bios, but still hangs... i also format several times..how will solve this problem
You mentioned opening a program and watching a movie and it hangs, remove one stick of ram and see if there is a difference, if no! remove second stick and put back the first and test again, if this solves the problem the memory needs to be replaced.
Apr 03, 2012 | Dell Vostro 1088
I have formate my lenevo 3000 y410 laptop 4-5 times, but hanging problem is not solved...in working time it's hang. but safe mode it's working fine. my os is windows vista home edition
If hang up all the time, and done many formats and still not fix, it It may be drivers, remove all drivers device manager, and replace one at a time, rebooting between installs, If that still not working, then it is usually bad hard drive, that needs replacement.
Feb 25, 2010 | Lenovo 3000 Y410 Notebook
Running Windows 7. A windows Critical Update auto installed on Thursday and system ran fine for several hours. Then it hung and I had to re-boot. It would not reboot, not even into Safe Mode. It would...
it more than likely has little to do with the operating system. It sounds like a hard drive problem. Are you able to format the harddrive and reinstall?
Jan 30, 2010 | Computers & Internet
Webroot 6.1 will not load on Windows 7
Are you running another antivirus program at the same time?
this will cause it to hang, maybe reinstall the program (repair) and see if this helps
Nov 13, 2009 | Computers & Internet
HP DV5 laptop extremely hot in Vista not Windows 7
hps are born hot. an undercooler board would help.
Jul 23, 2009 | HP Pavilion dv5-1002us Laptop PC
My acer travelmate 4052 laptop hangs several time,and needs reboot, give me solution,thanks
try clearing out startup programs that run in the background if you are using windows xp go to start click on run type in MSCONFIG, look for startup tab then uncheck the items that you don't need usual items that you need to keep on running is just the antivirus program. if you are using windows vista on start search type in MSCONFIG then practially do the same thing see if it stops locking up. hit me back on the results. thanks!
May 09, 2009 | Acer TravelMate 4000 Notebook
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
gggg
Alun Cox
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
