Question about Denon AVR-2500 Receiver
Can't find a radio frequency
I have a denon AVR2500. i have some problem which it can't find a radio frequency.i have connect the antena but it can't find a radio frequency. please help me solve this problem....
  • Ringgo87 Jun 18, 2008
    i was lost the manual...
  • Anonymous Aug 27, 2008
    yes, i have the same problem, my denon canot find a radio frequency, i tried a booster antena and still same problem, cannot find a frequency. everything else works find.
Do you still have the owners manual for the Denon AVR 2500? I just purchase one off of craigslist.org and could use some assistance.
Thanks,
Steve
Posted on Jun 14, 2008
  • 61 Answers
Check if the antenna is connected right. I assume it is FM. If AM and SW there are different antennas. Make sure the ends of the antenna connecting to the receiver unit is stripped. Best of luck
Posted on Jun 13, 2008
Can't turn on my DENON-avr2500
There is a internal problem with it, It is impossible to fix it with out haveing to replace certain things in it,
Dec 03, 2012 | Denon AVR-2500 Receiver
PIONEER AVH-P4000DVD 6.1" LCD 2-DIN CD/MP3/DVD IPOD NEW
Where are you located, if not the United States?
Aug 05, 2008 | Pioneer DEH-P690UB CD Player
I have a Harmon Kardon AVR2500, i want to connect my LP to the AMP, how is this done? Will there be variation in the sound out put.
Yes! there will, if the AVR2500 does not have phono inputs, the output sound will be barely there even at high volume. The solution is to find a phono preamp, Radio Shack use to sell them years ago. I suggest you try www.ebay.com and type phono preamp.
Jul 05, 2012 | Harman Kardon AVR 2500
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
Denon ud-m30 Tuner problem I can tune am stations, but not fm. Receiver doesn't even receive signals from my nokia n97 transmitter 5 cm away on the known frequency. Is it possible that fm unit is out of...
I have just solved this problem with my system - it is caused by bad connections between the boards. There are multipin connectors that connect the main boards together via a small vertical board. Check that these are fully connected and you will probably solve the problem.
May 30, 2010 | Denon D-M30 CD Shelf System
I installed an aftermarket radio speakers sub and amps, the problem is with the radio reception. does the factory amp have to be powered on for the factory diversity antenna to work? if so how can you...
the after market stereo has a wire called antena if if u bought a carwiring kit than all the wires should bethere just connect it and make sure ur antena wire is connected too
Jun 28, 2009 | Car Audio & Video
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Feb 04, 2009 | Denon PMA-100M Amplifier
Need Denon AVR2500 code for Direct T.V. rc64 remote
The remote code I used on my comcast motorola remote to control the Denon AVR 2500 I have is 1360 - worked like a charm
Sep 15, 2008 | Denon Audio Players & Recorders
Radio
You should be able to use any antena you wish. It uses a standard 75 ohm coaxial input. Any stereo shop should have antennas ranging from $5 to $100. Was that the only set-up problem?
Sep 11, 2007 | Denon AVR-3801 Receiver
269 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
