Question about NetGear WGR614 Router
Lost connection Hi- We have been using the router for a few months now and all of a sudden (after a lightening storm not sure if that had anything to do with it) we lost the connection. When you click on the icon on the bottom on the screen it says " Not connected". Not sure what happened and how to fix it. Let me know your thoughts.
    Novelist:
    Scholar:
  • 134 Answers
Certainly sounds like it has returned the configuration to default at the very least.. Maybe took a power hit & is dead.. But certainly worth some testing.. As this device does not contain a modem, I guess I can assume yours is external.. So have you plugged the ethernet (or usb) cable directly into a pc to prove it's actually the router? If you have, then I guess it worked & you can access the internet via the modem only? If it does not work, the problem is either the modem or the pc. Have you tried a cable (ethernet) directly from the router to the pc? It might be the wireless connection in the pc thats faulty? Then, the next test is to get into the router via a direct cable to an ethernet port, via the web browser..You might have to reset the modem to default to do that.. If you do not know what your router password is..? Also check your modem for correct lights.. Does your modem have lights on the front or side? How are the lights labeled? Pls get back to me, if you try these tests or if you need additional information on how to test the router.. Rgds,
Posted on Jun 13, 2008
My D-Link 2750U router is not working from last evening due to the heavy rain, lightning and storm. What should I do?
If you have lost three devices I'm sure you had ALL your computer devices on a UPS/Surge protector? Always connect ALL computer devices to a Power strip, UPS, or even better, unplug or switch off when not in use. A power strip with Surge Protection will help, most have a power switch/ Circut Breaker, to shut down ALL devices connected when not in use.
Feb 14, 2013 | Computers & Internet
Will not hook to my internet. we had a storm and lost power. now it will not connect back to netflix
Hi
This often happens with Routers and modems after a power cut.
Turn the router of and on again or press the reset button at he rear (some reset buttons are pressplates that you need a pen tip to press and hold for a few seconds).
After this, the router should reset itself and your internet access should be restored.
I hope this helps.
Aug 27, 2011 | Computers & Internet
Hi, I am not sure if this is my problem but there seems to be a problem with the network key on my laptop. We are using a belkin N150 router and in the last 3 months or so have been having problems getting...
I think resetting the router to the factory defaults may fix the issue. Generally, after resetting to defaults, the router works fine, however, you have to setup security key etc.
First, to reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router). The LEDs will then blink and the routers factory settings wouls be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 17, 2011 | Belkin (F5D7230-4) Router (587009)
I paid a guy to install/set up my new Belkin F5D8636uk4A router as my PC knowledge lacking......it worked fine till I switched power off and disconnected phoneline as we had a lightening storm. When all...
This issue is called no sync issue. Which means there is no synchronisation between your computer and the router.
Try Changing the Microfilter
swap the Leds of the cabel which is connected between the router and the computer.
Call your internet service provider if issue is not fixed.
Dec 20, 2010 | Belkin (F5D8231-4) Wireless Router...
Had a storm lightening struck something lights went out came back on but router dosnt have solid green light just flashing orange light modem dosnt see the router but if i plug in to laptop bypassing...
It appears lightening has damaged your router. Do you have a surge protected powerboard and do you plug all your computer equipment into this powerboard?
If you do not have a surge protection board, I suggest you install one to protect your equipment.
Aug 05, 2010 | Belkin (F5D7230-4) Router (587009)
After many months suddenly lost internet connection. Powered all down as directed, then powered up slowly , in order given. Also reset router. Didn't work. What should I try next?
Start your browser, click on the "Tools" button. Scroll down to "Internet Options, Click on "Connections". Make sure the box that states "automatically detect settings" is checked. Make sure that nothing is checked below in "proxy server". Reboot and check your connection.
Jun 09, 2010 | Linksys WRT54G2 Wireless Router
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
Has suddenly stopped connecting to internet on laptop. doesn't seem to get a signal or anything. main computer ok. seemed to stop after we had a thunder storm on thursday could this be something to do with...
Unplug your router. Unplug your modem. Wait 30 seconds. Plug your router back in and wait 30 seconds. Plug your modem back in and wait 30 seconds. Go to network connections under control panel. Right click on your network node. Enter enable. Wait a few moments and your network should come up.
Jul 11, 2009 | Belkin (F5D7633UK4A) Wireless Router
Wireless Connectivity lost
Greetings Roxie
Are you using XP or Vista?
The default ip address for a Netgear 192.168.0.1 - the default user is 'admin' and the default password is 'password'. Is it possible for you to run an ethernet cable from your PC to the router or from your laptop to the router so we can address its configuration?
Once you have connected the cable, wait about 30 seconds and then open Internet Explorer. In the address bar type 192.168.0.1
At this point the login to the router should come up. If it doesn't report back and let me know. If it does - log in using the default info I listed above. Verify that your connection type is DHCP. From there go to the wireless settings page. Make sure that wireless is enabled and make note of the name (SSID) of your network. Also take note of what channel you are broadcasting on. By default it is probably 6 but you should probably change it to 11. You can also enable or disable the security encryption from this page but lets disable encryption if it is not already disabled.
Once you have verified these items are present and enabled, save the routers configuration. Disconnect your laptop from the router. Unplug the power to the router. Unplug the power to the modem. Make sure all of the lights on the modem go out. Stand tall and sing our national anthem (wait about a minute) and then plug the modem back in. Once the online light has gone solid green plug the power back into the router.
Now go to your laptop and observe the little computer icon in the lower right by the clock. Does it indicate that there are networks available? If so - double click on it to see the available networks. Make sure you are connecting to YOUR network (the SSID we took note of earlier). If it says connected - you should be OK. If it says anything else let me know what it is. Good luck!
-C
Jun 20, 2008 | Dell Dimension 8200 PC Desktop
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
NetGear WGR614 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
