Question about Sony KP-61XBR48 61" Rear Projection Television
Videoscope XBR I pressed one of the buttons on my Comcast remote and the screen is now split in two down the middle. The cable image is on the right (compressed) and the left half has static (0 shows up if turning unit off and on as oppose to 3 on the cable side). I've tried unplugging the entire set-up hoping to reset, to no avail. I've tried all the buttons and no change. Any ideas?
Torned off the PIP option on the TVs own remote (cannot be done from the cable remote).
Posted on Jun 14, 2008
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a universal remote and need the code for a Sony Videoscope XBR projection tv
I don't know if all codes are the same. Comcast Cable gave me a list of codes for their universal remote for their motorola cable boxes. For Sony tvs it says either 0000 or 0111. I still use all 7 of my remotes. Universals are basically only good for power and volume. I need the other remotes handy to enjoy the other functions of my system! Anyway, hope this works 4-u and that you get better use out of it than me.
Sep 01, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a Sony Trinaton XBR about 6 years old. Works great. Have Comcast cable and they recently installed a new cable box. Now I get all cable channels on "Video 6 - DVD" rather than "Video 7 -Cable Box"....
I was awaiting your response in chat session but could not get any thing.
Please hook cable box in Video input-7 instead of Video input-6 in TV and select Video input-7 with remote on TV.
Regarding continues on-screen display of video-6, press Display button on TV remote once, on-screen display will disappear.
Thanks.
Jul 12, 2009 | Sony Televison & Video
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Televison & Video Logo
96 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
