Question about Averatec 3200 Notebook
Monitor won't display larger than 640 x 480 pixels. Can't change to native 1080 x 768
  • 2,229 Answers
This means that you need to reload the video drivers, as something has happened to them. Go to Averatec's site and look for the drivers for your operating system.
Posted on Nov 03, 2010
  • gbrickson Nov 03, 2010
    This happens all too often to need to do this operation.
    I can get it back to normal by using a previous Restore Point.
  • Art Ellison
    Art Ellison Nov 03, 2010
    OK, so you are not really looking at a video issue here. There's something on your computer that is changing your settings (basically telling your system that it no longer has the drivers needed). Perhaps even uninstalling the drivers. At this point, if the computer was in my shop, I'd scan for malware, do a registry scan with one of the registry cleaner/optimizers that I use, and check for Windows updates. This happening often is not normal by any means. You can also be messed up if you are running an unreliable registry "optimizer" the does its thing every so often. If you have any diagnostic software installed, disable it.
Blurry text
LCD monitors do best at their native resolution. There might be 2x2 pixels per spot at that resolution. Once you change the resolution, you might have 2.7 x 2.7 pixels per spot (merely an example). Although a resolution might fit well, at 3x3 or 4x4 pixels, all the other resolutions might look out of focus as each character bleeds over into an adjacent pixel.
The 16:9 aspect ratios are the only ones that will work correctly with this monitor; others will show black at the top and bottom or left and right, or images will be too tall or too wide.
The resolutions you should try are 1920 x 1080, 1280 x 720 or 800 x 600. When I look at resolutions available for my 16:9 ratio monitor, those are the three that are bold.. others are available, but would not show the high quality display.
There are also buttons on the front of the monitor to adjust the display left/right, up/down, re-size, focus, brightness, etc.. A change there could make a difference too.
Oct 30, 2013 | Westinghouse Electric L2220HW 21 inch LCD...
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
I have an AMD athlon processor. I want to set my screen resolution to 1920 x 1080 (Full HD). But in Properties --> Settings, this option is not there. My monitor's native resolution is 1920 x 1080....
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
May 24, 2011 | AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8...
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
Set pixels too high. Now monitor won't display.
Native resolution: 1280 x 1024 @60Hz, That is what you need to set the PC video resolution to. Running XP? Boot up in safe mode (hit F8 while booting up), set the resolution to 640x 480, then reboot into normal mode, reset the resolution to 1280 x 1024 @60Hz.
Mar 22, 2010 | Acer V193w LCD Monitor
What disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Averatec 3200 Notebook Logo
73 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
