Question about Intel Motherboard
Error when opening a program
When i tried to open some progrmas like yahoo messenger it gives an error and it doesn t open, so i tried to reinstal the progrmas but the problem persisted. also one minute i was surfing the net and next thing u know no wirelless driver found on my computer and no internet..how is this posible and how can i fix it...help pls:D
    Scholar:
  • 131 Answers
The best solution is to recover your pc with the cd that came with it. if you don't have the recovery cd let me know. write down the mdel of your pc. example=emachine t2080, hp 55555......etc Just post it to this forum and send the copy to email notify me that you are ready. I will then help you. I can easily help you if your computer is working with internet, but since there is no internet, you have to do a system recovery.
Posted on Jun 14, 2008
Connot open the yahoo massenger
If YM (Yahoo Messenger) is not opening or not working properly, I would suggest you to uninstall and reinstall it to your computer. Pls follow the steps below.
Uninstalling/removing YM:
Click Start> Control Panel>> Add and remove Programs, click.
On this page, look for Yahoo Messenger and click Remove, stay there until the page reopens with no Yahoo Messenger there. ReStart your computer, do not miss this step!
To reinstall YM to your computer, Visit this website http://messenger.yahoo.com/download/ and click download now.
Hope this help!
Sep 06, 2011 | Yahoo Messenger
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Application not found yahoo messenger
Hey.
It is possible that someone has accidentally uninstalled Yahoo! Messenger.
Try going to My Computer > C:/ > Program Files > Yahoo! > Messenger and here look for an icon of a smiley face :) that reads Yahoo! Messenger. Try to open that. If it doesn't work or if it's not there someone messed with your files.
In which case go to Yahoo.com click on Messenger on the left hand side and reinstall the Yahoo! Messenger application.
May 19, 2011 | Yahoo Messenger
Messenger 10. Newly download. XP operating system. When I try to view any cams I always get the message that the cam is Not Connected?
This problem occurs especially because you opened another program that uses your webcam. You should close any other program that might be using your webcam because a simple webcam can only interact with one program. If it doesn't work, try reinstalling it / then messenger with another version.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Yahoo Messenger
Getting this error message while opening the Yahoo messenger...not able to use Yahoo Messenger....
Try to Uninstall Yahoo messenger. Restart your computer then reinstall it again. if it still doesn't work try giving me the error message so that i can give you the exact solution.
Apr 09, 2011 | Yahoo Messenger
Hello ! My name is Cristi and i have a problem with my yahoo ID and e-mail account. From almoust 3 months...
First, try signing in with your Yahoo! ID here: https://imo.im/
You should be able to log in there. To fix error 81003002, you will need to do a complete removal and reinstallation of Yahoo! Messenger. I will give you 2 of the best ways to go about this:
The first way is to use Revo Uninstaller. (Recommended, requires a program installation)
( found here: http://www.revouninstaller.com/start_freeware_download.html )
You can use Revo to uninstall Yahoo! Messenger, making sure that you do at least a moderate level scan of your system using Revo. Delete everything that Revo asks you to. This will make sure that all files and keys related to Yahoo! Messenger are also erased from the system.
The second way to uninstall is to do it manually. (NOT Recommended, no installations)
Open your start menu, then click Control Panel. Navigate to "Add/Remove Programs". Find Yahoo! Messenger in the list, then uninstall it. Reboot if prompted. After it successfully uninstalls (reboot if prompted), go to "C:Program FilesYahoo", or if it is not there, "C:Program Files(x86)Yahoo". If you see a folder called "Messenger", delete it.
Reboot your computer, then reinstall the latest version of Yahoo! Messenger. You should be able to login now. If you are unable to log in, and you uninstalled Yahoo! Messenger using the second method, then you will have to use the first method.
Mar 30, 2011 | Yahoo Messenger
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Cannot open my yahoo messenger
you might need to uninstall the program, and reinstall it one more time , pls go to yahoo's website and install the latest version.
it could be corrupted
Aug 14, 2008 | Yahoo YHT-630 System
Run time error when i try to open up yahoo messsanger...
You need to uninstall and re install the yahoo messenger, If still not fix the error you need to scan your computer maybe your system infected by the spyware virus. Update your installed antivirus with capable to detect also the spyware virus. If need a free anti virus just download in the www.grisoft.com and also www.pctools.com there is free edition that you can download and update the virus data to detect the new virus and spyware.
Apr 29, 2008 | Computers & Internet
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
