Question about GE 36 in. Profile JGP962 Gas Cooktop
The control locks.. locks the whole stove even if the control i set to unlock? what couldt it be ?
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
Oven door is locked somehow
UNplug it and let it sit for a half hour to a hour then plug it back in and it might reset itself.
Jan 05, 2013 | Maytag Stove / Oven / Range Cooktop -...
Are replacement decals available for the heat settings around the stove knobs?
I just spoke to GE about this, NO, they DONT have decals, instead they want you to replace the whole Cooktop piece for $300 +...
Am so annoyed.
All my neighbors who have the same appliances put in by the builder are having the same issues. It's a GE problem.
Apr 05, 2011 | GE 30 in.JGP330 Gas Cooktop
My induction cooktop is locked and won't unlock.
either control panel or keypad has gone bad.
Jun 21, 2009 | Cooktops
How do I unlock the burners?
there should be a key that you have to press and hold to unlock. find it and press till the light is gone let me know how it goes
Jun 12, 2009 | Dacor Millennia ETT304 Electric Cooktop
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Unlock stove
Unplug w/in an hour and put it back observe if is lock or unlock.
Dec 26, 2007 | Electrolux 23 in. EHS6651P Electric...
GE 36 in. Profile JGP962 Gas Cooktop Logo
23 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
