Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
CAN YOU TELL THE PROPER TIMING PROCEDURE FOR AN INTERNATIONAL HARVESTER TRACTOR 806 WITH A RD FUEL INJECTION PUMP. I HAD THE INJECTION PUMP FIXED AND NOW I DONT KNOW HOW TO TIME IT. CAN YOU HELP?
2 Suggested Answers
SOURCE: Torque pattern
I went to my local Tractor Supply store and they had 1 manual that covered my tractor. It had the torque pattern in it. I purchased a torque wrench while I was there and went home and installed the head myself. First time I ever tackled a job like this. After assembling all the other parts and giving the breather a little shot of either, it fired right up , hooked a set of 3 plows to it and put it to work. Thanks for your interest, Donald
Posted on Apr 14, 2009
4cyl diesel Ford tractor. Ran great yesterday . Today it starts and cuts off. Any ideas?
Is the fuel flow strong at the injection pump ? If not you may have a partial blockage inside the tank, wouldn't hurt to change the fuel filters either. I had a similar problem with my 350 JD dozer
I checked the tank and found some debris covering the outlet hole,
debris removed problem fixed.
Also check all your fuel lines, if all the above is good, than start cracking each injector one at a time with the machine running
as long as it will run, you will notice a bad injector by the difference in sound , a good injector will cause rough idling l a bad one will not.
Aug 10, 2014 | RTO Ford Tractor 2000 3000 4000 5000 Water...
I have a 91 f350 7.3 liter idi. It will not start
cranks ok , and fast?
after checking all fuses. (the FSM shows correct fuse)
International Harvester IDI (from Indirect Injection) engine is a 4-stroke 8-cylinder Diesel engine used in International Harvester trucks,
like all diesels check fuel filters first. (service)
then make sure glow plugs work. (fsm covers this)
then scan it EFI for DTC errors. got errors?
direct injection uses EFI.
IF DIY, you need the book, I promise.....
its not simple like old diesels were.
May 03, 2014 | Cars & Trucks
How do i rebuild a mitsubishi l300 fuel pump
Don't sound like a fuel pump,replace fuel filter and see if it fixes.
Jan 05, 2013 | Cars & Trucks
Transit pump code p0216 how can i fix this
P0216 DTC - Injection Timing Control Circuit Malfunction and this means the diesel fuel injection pump has a timing failure. This could be that the injection pump timing needs adjusted OR the failure is internal to the injection pump and therefore non-adjustable.
NOTE: If your vehicle is a Dodge Ram with Cummins engine then be aware that fuel delivery problems frequently cause this code. Prolonged fuel delivery problems can cause injection pump failure!
Symptoms of a P0216 DTC may include:
Low power
Crank, but no start
Hard start
Displays an intermittent stumble or miss
Engine may start and then stall
Engine may appear to drive fine but surge at idle
The most frequent cause of this code is a bad injection pump due to poor fuel delivery. Fuel delivery problems could be:
A plugged diesel fuel filter
An in-tank blockage
Air in the fuel due to a cracked in-tank fuel ine above the fuel level
Bad transfer (lift) pump
Injection pump out of time
Possible Solutions: First, simply check if your injection pump timing is adjustable. If so, check the timing and adjust if necessary.
If you think that you may have a fuel delivery problem, then check the lift pump operation. On Dodge Ram with the Cummins engine, the lift pump should produce about 45 oz of diesel in 25 seconds of operation. This can be performed by disconnecting the fuel hose from the injection pump and pumping the fuel into an approved container. Bump the engine over but do not start it. Then the lift pump will operate for 25 seconds. If the fuel is aerated, then check/repair fuel line and recheck.
With the fuel hose connected the fuel pressure should be 10psi. If the fuel delivery tests fail, replace the diesel fuel filter and recheck.
If it still fails then verify there are no restrictions in the fuel tank
Then replace the lift (transfer) pump. IT SHOULD BE NOTED that if this code surfaced after a routine fuel filter replacement or if you have any of the above symptoms after routine fuel filter replacement, then suspect the fuel transfer pump. This occurs because even a weak transfer pump can still provide enough fuel for the engine to run. But when the fuel system\'s prime is lost due to fuel filter replacement, it may not restart again without fixing the fuel delivery problem.
If you found your injection pump to be bad, the lift pump should be checked for operation to protect the new injection pump. This is because weak or low output from lift pump are common cause of injection pump failure. There are some aftermarket kits that can be purchased to warn the operator when the fuel pressure/volume drops to level that could damage the injection pump.
Hope this helps (remember to rating this free answer and leave a testimonial comments).
Oct 11, 2011 | Cars & Trucks
The injection pump loses it prime . so i run it on starting fuild until it picks up then it runs fine. I cleaned the fuel filters and all the line. I think it might be the fuel pressure valve maybe
Most of the time the problem will not be in the pump. I have seen the check vale inside the pump do this not too often. How about the fuel pump itself? I have seen this alot!!! It is the one you pump to prime the injection pump.
Jul 16, 2010 | The Times Case Corporation Tractors...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
649 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Jerry Radcliffe
Bud H
Are you a Farmall Toy Expert? Answer questions, earn points and help others
