Question about HP PSC 2175 All-In-One InkJet Printer
Will not print and msg says to check cartridges- have taken them out numerous times, cleaned them, turned printer off...nothing seems to work. Is there a reset button?
  • 6 more comments
  • scott558 Nov 04, 2010
    The reset did not do the trick. It was initially saying check right cartridge, then somewhere along the line- probably during one of my reboots- it starting saying check cartridges. After reset, it now says check left cartridge. The left cartridge is out of date (2008- b/c I never use color) but it has been working fine with that cartridge for over a year so can't understand how that could be the problem. I tried to run it without a left cartridge but it doesn't seem to like that. Any other thoughts?
    This response does not make any sense to me. Why would the printer work fine with an out of date cartridge for 2 yrs and suddenly not work because the cartridge is out of date? There is plenty of ink in both cartridges.
  • scott558 Nov 05, 2010
    The printer was not connected to a pc- I have a laptop. The problem occurs when I turn the printer on- without it being connected to the laptop- so I don't see how uninstalling and reinstalling printer drivers could have an effect (but am certainly willing to do this if you still think it might help). I checked the cartridge and the ink is not dry. However, in response to your comment about the contacts, I decided to try an old color cartridge I had laying around. Thr printer accepted this but now it will not print the alignment page correctly- it continually prints the first line and then spits out the paper. Do you have a suggestion for this- or is there a way to bypass the alignment?
  • scott558 Nov 07, 2010
    NOt sure if you got my reply to you as I have not rec'd a response from you. Here it is again:
    scott5582 days ago
    Nonontech: No, I was replying to Caroldon. I had not seen your comment. That is simply not my experience. I have used cartridges for much longer- years in the case of color cartridges b/c I almost never print in color. I have refilled black cartridges 2 or 3 times and had them last a year. I print infrequently and it doesn't seem to be a problem.
  • scott558 Nov 10, 2010
    Caroldon; Maybe I pushed the wrong button and you did not get my reply- sent Friday. I am really struggling to be without a printer and hope that you can help. Here is what I replied:
    I have not heard from the last expert for 5 days so would like to find someone else who can help me. I don't need any more input about outdated cartridges as that has never been a problem with this printer. At this point I have gotten beyond the "check cartridge" issue and am now struggling with the alignment page. It prints the first line or two and then spits out the paper- again and again. Is there a soln to this or a way to bypass alignment. Thanks!
  • scott558 Nov 17, 2010
    Followed your instructions including checking printer for particles of paper, dust, etc, cleaned cartridges and reset to default. Still will not print alignment page- prints a line or two and then says: "alignment cancelled." Can anyone help me with this? Is there a way to bypass alignment?
  • 4,281 Answers
First make sure there is not any leakage on ink cartridges. Clean dust and small paper pieces from all parts of printer. make sure ink cartridges are compatible with your printer try with another ink cart.. then check. Also perform the ink cartridge cleaning operation. For that follow below On the front panel, press the Menu or Setup button (depending on the model). Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model). The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
You can reset all settings of printer to defaults. For that press menu button and then go to settings then reset all to defaults. Then this error will be fixed. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 11, 2010
  • HP Master
  • 4,737 Answers
Could you please let me know how long have you been using those cartridges? I hope you know the lifetime of an ink cartridge. No matter what, whether you use them or not, whether you refill them or not, once it's unpacked from the printer and has been installed on the printer, most cartridges will definitely die after 5 months. In rare cases, some works longer or more than a year if you used to print few copies every month.
Awaiting.
Posted on Nov 05, 2010
  • Lebanon Raingam
    Lebanon Raingam Nov 05, 2010
    Was that a reply to my comment?
  • Lebanon Raingam
    Lebanon Raingam Nov 07, 2010
    Ok.. Never mind.. All the best..
  • HP Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
If not the possibility of the printer head being defective is high. make sure the cartridges are of the original make.
Posted on Nov 04, 2010
  • HP Master
  • 1,679 Answers
First step is to check if the cartridges are empty if you haventt replaced them lately.
There is an expiration date on both the cartridges.
Check if the expiration date is ending any day from today ( i.e the year should be atleast 2011 and if 2010 it should be more than Nov 2010 )
If any of the cartridges has expiry date less than Nov' 2010 then you will have to replace the cartridge.
HP Printer will not accept any cartridge with expiry date less than current date as they are designed the same way. ( though the printer must have been using the same cartridge for long time )
There is a reset for this printer : you can try this before replacing the cartridges
Press and hold Cancel and the Right Arrow while plugging in the power cord
Hope this would resolve your issue
Posted on Nov 03, 2010
  • ONE-Touch-Solution
    ONE-Touch-Solution Nov 04, 2010
    I understand it was working till date but now it is not and this is how the printer is designed. You will have to replace the cartridge to make the printer work
    Maybe only HP can answer you this since i do not have much information as to why your printer worked fine. I have given you all the details you needed and i did mention that the Printer must have detected that the cartridge date has expired and does not accept it any longer.
    This whole thing is based on the cartridge install by date, cartridge usage, and cartridge life. if you are using a cartridge for 2 years and have not used it much and have not changed, there are chances the nozzle's must have dried and hence resulting in printer to reject the cartridge.
MFC7860DW PRINTER. USB CONNECTED TO DELL OPTIPLEX 380/ WIN 7 64 BIT. UNABLE TO PRINT. fax receiving data msg on printer display. Tried may fixes offered by Brother and other articles. Nothing works
'Unable to print' is to broad to know what's wrong.
You get a fax receiving data msg every time you try to print? Try reinstalling/updating the software.
The printing head moves as if it's printing and nothing comes out on the paper (I assume there is ink on cartridges) maybe the printer was sitting for too long and ink cristalized, going through several 'cleaning' cycles might fix it.
Hope it helps.
Dec 16, 2017 | Brother Office Equipment & Supplies
Both "check print cartridge" and "check paper" lights are blinking and "E" is in the numeric count display. Just replaced the cartridges w/ new ones and nothing seems to work. What do I do?
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Sep 02, 2010 | HP PSC 1410v All-in-One Printer
Doesn't print black ink
Have you taken the protective film/sticker off the cartridge? - so the ink can get out...
May 06, 2010 | Brother MFC-685cw InkJet Printer
Replaced black cartridge in my lexmark 3500-4500 printer. message reads "left cartridge incorrect". Have taken cartridge out and put back in numerous times still get this message.
You may have bent or broken a sensor wire. Check how the other (color) side looks by removing cartridge and confirm that nothing is awry. Otherwise, clean the metal contacts on both printer (power off and unplug) and cartridge with rubbing alchohol and a cotton swab, then try again.
Aug 18, 2009 | Office Equipment & Supplies
Epson cx7800 won't detect magenta ink.
It seems likely that either your magenta cartridge is faulty (or empty - the ink monitor doesn't show how much ink is actually left, only the amount used subtracted from a presumed full cartridge when new). The first thing to be sure of is that you have a good cartridge - install a new one. You can save the existing one for later use once things are OK again. If this produces no results, you can now be reasonably confident that you have blocked magenta nozzles. Note that putting in a cartridge and taking it out again several times will aggravate the situation by getting air into the system.
You can now try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Feb 18, 2009 | Epson Stylus C86 InkJet Printer
Just opened box today 12/14/08 error msg: cannot recognize ink cartridges. I just completed step 4-9, checked cartridges 4 times pressed OK BUTTON 4 TIMES, same msg. note: all cartridges are new! checked  ...
Same problem with the one I have. Have always had that problem. Seems like cartridges from Mexico work better. If at first it dont work, JAM IT IN. What the hell, if the printer breaks, you aint lost nothing but a printer that wouldn print anyway.
Dec 15, 2008 | Epson RX595 Photo All-In-One Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Did you make sure that the colored tape was removed from the back of the ink cartridges? The manufacture puts the tape on there to protect the circuits during shipping. If the tape is still there it would not be able to communicate with the printer or computer.
Sep 19, 2007 | Canon PIXMA iP1600 Printer
HP PSC 2175 All-In-One InkJet Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
