Question about MSI K8MM-V Motherboard
My system is having the motherboard K8MM-V(601-7142-010). Every time, when I switch on the system, the time & date are to be updated. I changed the MB battery and scanned for virus. Is it a MB problem? Should I change the MB. Is it now available in the market? Whome should I contact at TRIVANDRUM - Kerala.
    Sniper:
  • 75 Answers
Check if MB Battery socket has problem.
Cheers!!
Posted on Nov 20, 2018
SOURCE:
antiochpc
  • 1314 Answers
SOURCE: Need PDF User Manual & Drivers Please!
The drivers can be downloaded from here: http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173 The manual can be downloaded from here: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
Posted on Jun 23, 2007
  • 928 Answers
SOURCE: K8MM-V Motherboard Prob
If you are talking about the sound that the computer does for when you turn it on, it's a small round speaker with two thin cable connected to a plug, if this is not connected to the mother board, then you won't be able to hear it.
Posted on Aug 31, 2009
  • 17 Answers
SOURCE: Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Posted on Dec 18, 2009
  • 2679 Answers
SOURCE: what is the latest bios update available for this motherboard?
If your PC is working without any problems leave the BIOS alone. If you don't know what you are doing you can make your system unusable.
BIOS updates should only be done by those with a good knowledge of Operating Systems and are not for the amateur.
If you knew what you were doing you would not be asking the question.
Posted on Dec 27, 2009
  • 133 Answers
SOURCE: in my MSI V CLASS K8MM-V motherboard the raid
Here you go:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Posted on Apr 21, 2010
BIOS won't recognise SATA hdd.BIOS is Pheonix-Award BIOS v6. 00PG. Do you think I need to update the BIOS?
Hi, according to your mobo manual it supports SATA1/SATA2 hard drives so it's recommended to update BIOS, the latest I found it has release date 2006-06-29, you can find it in the folllowing link: Support For K8MM MSI Global
Nov 07, 2017 | MSI K8MM-V Motherboard
Will K8MM-V MS-7142 Motherboard supports 500GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI K8MM-V Motherboard
Problem with BIOS. Cannot change system date.
Put all default setting on CMOS setup and then set the date by checking that the replaced one battery is energetic enough to meet the system requirement. I mean to say having 3V as it should have.
best of luck!
Mar 11, 2012 | ASUS Motherboard P8P67 PRO REV 31 Core...
My windows time is getting slow gradually. What should i do ?
There could be two reasons for the same,
1. The coin cell battery is drained and need a replacement
2. The motherboard software (BIOS) has gone bad , would require an update .
The following link is the BIOS update link for the motherboard. Before update make sure , all external peripherals except the keyboard and mouse has to be disconnected . Also verify the the existing version of the BIOS
http://www.msi.com/product/mb/K8MM-V.html#/?div=BIOS
If the above steps donot help, Then the motherboard needs to be replaced.
Thanks for using Fixya
Proton
Aug 27, 2011 | MSI K8MM-V Motherboard
VGA driver
you can download it her http://www.google.co.id/url?sa=t&source=web&cd=1&ved=0CBQQFjAA&url=http%3A%2F%2Fwww.driverstock.com%2Fdownload-MSI-K8MM-V-driver%2F14-9-11420%2Findex.html&ei=MxwrTdfCOYHirAf2kL3EDA&usg=AFQjCNFAMaOKoXTwGflQMtbxwYu51iWDKw&sig2=psodhCcbsSWmlKlY06wGYQ
Jan 10, 2011 | MSI K8MM-V Motherboard
Always start up with cmos checksum error, cpu ratio has been change
A BIOS checksum error is most likely caused by a flat BIOS battery.
Replace the battery with a new one (it is usually a coin size battery - type CR2032) and then boot up and go to the BIOS configuration and set the Date & Time setting etc.
Jun 30, 2010 | MSI K8MM-V Motherboard
System Time and Date Change
It is because of CMOS battery is weak
Change it and it will be fine
May 20, 2010 | AOpen vKM400Am-S Motherboard
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Ibm bios problem
ibm i845 bord date & time save nahi hota cell b change kia ha pls solve problem thx
Dec 17, 2008 | IBM (03R0329) Motherboard
MSI K8MM-V Motherboard Logo
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
