Question about Sentry HO900 Headphones
Won't shut off
My headphone won't shut off. The on/off button doesn't work and to use them I have to take out the batteries when I finish.
  • Anonymous Dec 24, 2008
    Same problem here
    Problem Solver:
  • 17 Answers
These headphones are NOT a very good quality and if your on-off switch broken, it's not much use anymore. Taking out the battery is one solutions until you get tired of it and pitch the thing in the trash :)
Posted on Apr 09, 2009
My Samsung ER-4915 won't open drawer when cashed out
It sounds like someone has reprogrammed the status of the cash button. Can you finish the sale with a different payment type such as credit card button?
Jun 26, 2013 | Samsung Computers & Internet
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
My headset will not get out of pairing mode. The blue light stays on. The only other color I see is red when I shut it off.
Make your phone (I'm assuming) forget the S-9 and search for Bluetooth devices again. It will find it again, but it won't be paired. Press whatever button on your phone that makes it connect and it should work. I've been searching for answers and racking my brain. Finally, I just tried this and it worked! What a relief...
Apr 05, 2012 | Motorola Mobility S9 Headphones
Computer working perfectly fine one day, the next computer won't turn on for no apparent reason. when switching the power button on, computer begins to boot up for a brief moment, then automatically...
It's probably your logic board. One thing you can try that may help you out is to take out the battery (if you can) and press and hold the power button for 10 seconds. If it's a capacitor problem on the board that should discharge it. If that doesn't work then you should probably try to turn on the computer while holding CMD + Option + P + R to reset the PRAM. If that doesn't work then you're probably going to have to seek professional help.
Aug 04, 2011 | Apple Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My ipod was working today now its not even turning on, its just a blank screen?
First and easiest solution is it may have been left on and the battery is dead, so plug it in and try that first. If that doesn't work, press both your menu button and the center (select button) for about five seconds, hold them down until you see the apple logo appear on the screen. That is your reset option. It will go through a shut down/reset process. When finished, turn it back on and enjoy....Brian
Jun 29, 2011 | Apple iPod nano 2nd Generation MP3 Player
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
While i was trying to update my nokia n73 turned off and now i can't turn it on,and my pc doesn't recognize when i connect the phone turned off
Did the update finished with out an error?check your battery,if the battery is too drained,you won't able to charge the phone.If this method doesn't works,there's a problem on the update process.
to be able to retrieve your phone,ask assistance to a mobile phone service near you.they will glad to assist you on your problem..
Jun 12, 2011 | Nokia N73 Cellular Phone
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Sentry HO900 Headphones Logo
139 people viewed this question
Top Sentry Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Tom Chichester
Are you a Sentry Audio Player and Recorder Expert? Answer questions, earn points and help others
