Question about Kenmore 45981 Washer
My kenmore front loading washer model # 45981 400 has an F 11 code. I push the cancel/pause button and then start it back up and sometimes it will finish the cycle then or sometimes i have to hit the cancel button 2 or 3 times to get it to finish. What is this? can i get parts to fix myself
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa
Posted on Nov 03, 2010
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a front load kenmore washing machine and keep getting a F-11 error message, what do I do? I do as the manual said and push pause/cancel twice and sometimes it will let me restart and sometimes not.
fll error code is a communication error between (ccu) central control unit board and the (mcu) motor control unit bottom control board .... replace control board on the top of machine
Jan 23, 2011 | Kenmore Elite 45986 Front Load Washer
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Control panel
Are you sure the door is closed properly? Give it an extra push. The start/pause button could also be damaged/faulty. Try switching the machine off at the wall socket and on again.
Nov 03, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Kenmore 45981 Washer Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
