Tv has a line going thru the centre of the screen when i turn it on its like the whole picture has gone into a thin line
  • 4,234 Answers
This is a problem with the vertical circuit and can be either bad connections at the vertical IC or a defective IC. This is a common problem and is easily repaired. The vertical IC is a small flat IC attached to a heatsink with about 11 pins or so. It might be marked LA7837 or something similar. If you can solder, try resoldering the pins on that IC first. If that fails to resolve the problem, replace the IC. Expect the IC to cost about $15-$25 depending upon the exact one. It is possible that some of the capacitors in the same circuit are defective as well. Once the IC is replaced/resoldered, report back here with the results and we can go further if necesary.
Dan
Posted on Jun 13, 2008
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
White horazontal lines on whole screen
Check the horizontal block of your tV set and if you could not find any soldering anomaly, then reolaced the horizintal IC.
Mar 30, 2013 | Samsung HL-P6163W 61" TV
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
Thin line of no picture across tv screen
this is a resistor gone on the board easily fixed
Jan 17, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Feb 27, 2008 | Televison & Video
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
