Question about Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G v6. cannot connect wirelessly
I just moved into share accommodation and am trying to connect to my room-mate's wireless. He has the password and everything, but we don't even get to enter it. When I search for the network, his comes up very strongly, but when we go to connect to it, it says the network is out of range and to refresh+retry. This happens even when we are right next to it and it is the strongest network in range. A friend suggested I download software for the router? Any help would be much appreciated.
Hi Bne78,
Although changing the software used to connect to the program might work, what you might wanna find out is the kind of security that is enables on the router. Find out if it;s MAC authentification, WEP encyption or simple plain hidden SSID.
Once you have determined the type of security that rides on the router your friend would have to do one of the following:
1. Issue you the SSID name of the router
2. Issue you the WEP key used to secure the network
3. Add your MAC address in, if he uses mac authentification.
Other than which, to my knowledge, connection to wireless access points usually work best when you use intelproset wireless program. That kinda solves the whole deal. Let me know how it goes. Dont hesitate t get back to me on this issue. Thanks.
- Technomancer.
Posted on Jun 16, 2008
    New Friend:
  • 50 Answers
Go to main computer, go to the address bar type in 192.168.1.1 at the user name leave blank, in the password bar type in admin, go to the set-up tab, check the password, go to your computer, do the same, and should be up and running, let me know, and we will go from there.
Aloha
Bob
Posted on Jun 14, 2008
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
I have both a WRT54G v2.2 and a WRT54GS v6. Same Power Specs?
I have the Linksys WRT54GS ver 6 wireless router. It uses a 12VDC power supply @ 500mA. The center of the post is + and the outside of the post is -.
May 10, 2010 | Linksys Wireless-G WRT54GS Router...
I cannot print over wireless connection. I am using the Linksys WRT54G. I am trying to print from my laptop to my HP LaserJet 1320 PCL 6 printer. I cannot see the printer from my laptop. I am using AVG...
Disable your firewall on that computer where you shared your printer.
After that check firewall settings to allow printing from the network.
Your router working ok.
Feb 28, 2010 | Linksys Wireless-G WRT54G Router
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I have a WRT54GS router,also have A Wireless G Adapter, can i use
If you have the printer connected locally to a computer on your network, you can share it out and then connect to the printer share name via the network. Your other computers must be connected to your computers via wireless or wire.
Dec 27, 2009 | Linksys Wireless-G WRT54G Router
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Not really a problem - but a question
Remember that router will use only 54Mb of bandwidth which will be shared across all users (as long as router is used as access point). Simple mathematics:
1 user = 54Mbps
2 users = 27Mbps
10 users = 5Mbps
Also please note you might have further probems with channel interferences between users when you have all users in the common area
Also remember that 54Mbps will be only wireless Speed. They all will share common Internet connection
Jun 08, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
88 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
