Question about Kenmore Elite 45986 Front Load Washer
F-05 Error code
Thanks very much for responding to my problem. I managed to get the bottom panel off the other day and the black connector was disconnected so I just plugged it in and the washer works perfectly. I guess it vibrated loose. It plugged into the bottom of the tub and had two wires. I'm not sure if it is the one you were referring to. Thanks for helping.
  • 5,911 Answers
Yes this is the very connector that I was describing to you. Glad you were able to solve your problem and didn't require any parts. If you get the chance, refer back to your original post and rate this solution please. Good luck to you.
Posted on Jun 13, 2008
Error f0-05 showing during cycle
Error code F05 means water level switch is stuck on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove and clean filter inide hose.
Refit and test.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wd640 problem not pumping out f-05
Error code means pressure switch jammed on full.
Remove large black hose fastened to bottom of drum
Remove hose on to pump and check for blockage or obstruction here as well
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove large black hose from bottom of drum.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
I am getting an F-05 error
Error code F05 indicates that the pressre/waterlevel switch is jammed on full.
Remove hose onto pump, check for obstruction here, and into the pump.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
MY HOTPOINT WD860 WASHING ACHINE HAS FLASHED F 05 DOES ANYONE KNOW THIS PROBLEM CODE.THANKS
F05 indicates that pressure switch is jammed on full.
Remove lower rear panel of washer, and locate and remove large black hose on bottom of drum, remove and clean filter inside of hose.
Thanks.
Aug 30, 2009 | Washing Machines
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error Code F-05
"F05" is an indication of a water temperature sensor (NTC) error. Check the Water Temperature Sensor and check electrical connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor.
The part number is 8181705 and listed as "NTC" at Searspartsdirect.com. Just type in your model number and you will find the part under the "Tub and Basket" heading. The best part only costs $9.75.
If your items are stuck inside the washer and pushing the "Pause/Cancel" button does not unlock the door, you will need to pull the manual release to open the door. With the bottom panel removed, reach up behind the front panel near the door latch. Locate the bottom of the door latch and you will find a round tab. Pull this tab straight down and the door will unlock.
I hope this helps you. Please post back if you need further assistance.
May 22, 2008 | Indesit Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
21 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
