OKI C5900 The error code is SERVICE CALL ? 980 ? Fatal Error.
  • 2 more comments
  • tec_planet Jun 17, 2008
    I have the same problem, but with the OKI C5800. Fatal error 980
  • imagenastral Jun 21, 2008
    we have the same problem but with Oki c5500
  • Amit1980 Jun 23, 2008
    Change the fuser, this helps!!! Thanks....
  • Anonymous Jan 19, 2009
    i'm also facing the same problem with OKI C5900 after a paperjam...Service Call, 980: FATAL ERROR.
We have the same problem but with Oki c5500
Posted on Jun 21, 2008
  • 13 Answers
Most likely you have paper wrapped around the fuser or at least stuck in the fusers sensor So remove anywhere you can see paper. If not it will need a replacement fusing unit.
Posted on May 01, 2009
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
Jul 07, 2008 | OKI C5500n Printer
Error 980 on OKI C5900 fatal error
First, there is no model C5900. There is a model C5800. On the assumption that you are having this issue with a C5800 then the problem is media wrapped around the fuser. After cooling you can try to unravel or unwind the wrapped media but you may need to replace the fuser.
Jan 20, 2014 | Oki Electric Industry C5900N Led Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
3,058 people viewed this question
jasbo
jasbo
