Back to:
Tags:
ASUS P4P800 SE  Motherboard
Time / Date
posted by mgetsinger on Jun 13, 2008
Just built System using P4P800 Motherboard and noticed that everytime I turn the pc off the time and date do not advance.. I have to change it everytime I turn the pc back on... is the a bad battery??
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 16, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Just built System using P4P800 Motherboard and noticed that everytime I turn the pc off the time and date do not advance.. I have to change it everytime I turn the pc back on... im replace the new battery.but same problem??
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Time / Date:
I don't want to Accept this solution
Solution #2
posted on Jun 13, 2008
Not Rated (0)
Zorbathegeek
Rank:Master Master
Rating: 85%, 11 votes
Almost certainly it's a bad CMOS battery. You can get a new one for a couple dollars at most drugstores. You want a CR2032.
Thank You!
Solution #3
Not Rated (0)
jabba316
Rank:Guru Guru
Rating: 85%, 42 votes
this could be a service not running, go to your start menu and type services.msc in the run box and hit ok.you will get a service window up with whats running, scroll to the bottom and make sure windows time is started. if you right click on it and go to properties you can set it to automatic then it will startup every time you turn on your pc.
hope it helps
Thank You!
Can you Help with these Motherboards problems?
Motherboards
Iwant MSI SAVGAfor my computer
Motherboards
hELLO, System not booting. checked all the hardware to...
Motherboards
I put my computer together and I don't seem to get a...
Motherboards
hey i need help with my problem that im haveing with my...
ASUS P4P800 SE (890552603657) Motherboard
Cuando enciendo la computadora , me sale una pantalla az?l...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
