Question about GE JE2160 Microwave Oven
We have a GE JE210 microwave that no longer works. Last week it tripped the breaker. I flipped it back on and it worked. Just the other day, it tripped the breaker again, flipped it on, and it now has no power at all. Plug works. Microwave does not work on any plugs. Could it be the magnetron? The unit is 3yrs. old. Any thoughts on fixing it? Thanks.
    Sergeant:
  • 268 Answers
The magnetron will not cause it to trip the breaker. Shorted High Voltage capacitor, or transformer, or bad door switches more likely at fault.
Posted on Oct 09, 2017
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
freetek
  • 5569 Answers
SOURCE: GE Microwave JE1640WB blows circuit breaker
The problem may not have anything to do with the magnetron.
It is a device that uses DC for operation and to supply that, there is one or more heavy diodes that are more likely to fail first.
Have also seen the transformers fail occasionally too.
Frankly, it may be time to dispose of it since you will likely be billed for the repair if the magnetron is not at fault and once they have it, you don't know if the truth is being told or not.
Another possibility is a circuit breaker on its way to the grave.
If you care to go to the trouble, you might shut down the main breaker in the breaker box, swap the tripping breaker with another of the same rating and try the microwave one more time.
The surge current the microwave draws is probably a good bit higher than the hair dryer and might be enough to trip an aged breaker.
Posted on Mar 27, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: GE Spacesaver microwave question
A microwave should always be on its own breaker to prevent the breaker's being tripped. If that happens too often it can wear out the breaker and/or the outlet. But that won't damage your magnetron.
I would say one of three parts has failed, the high voltage rectifier diode, the magnetron, or the high voltage transformer.
Here are some links you or someone you know can use for testing (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's the magnetron, and it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 22, 2008
SOURCE: No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Posted on May 14, 2009
  • 4 Answers
SOURCE: dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
Posted on May 27, 2009
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
I have a 20 year old GE JCM140H over the range microwave which has always worked just fine. Last week everything just "died" no lights, no fan, no display, no microwave. I thought that I had...
You'll have to remove the cabinet cover to access the fuse. It is in line with the power cord. 20 Amp, slow blow.
One of the screws on the back of the cover may be a security TORX (the kind with a pin in the center of the head). Usually, if you tap on it with a hammer, you can remove it with a pair ov Vise-Grip pliers.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave tripped the breaker, When i flipped the breaker back on microwave no longer works. How do I reset it?
It may be a blown fuse, cavity thermostat, magnetron thermostat, or a problem on the control circuit board.
Having the brand and full model number would have helped us help you.
At our Web site, we have a video available showing how to remove a typical over the range grille in under 5 minutes. Often the fuse is behind the grille.
You can find helpful exploded view diagrams and order parts for most brands by entering your full model number from the tag on the oven here.
For other brands, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Model WES1450DM1BB I boiled 4 cups of
Owners of a GE WES model might want to look at this blog post.
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
Dec 24, 2009 | GE Microwave Ovens
Lost power suddenly.
drsclark2,
check to see if the breaker for the microwave has tripped, you may need to shut it off then flip it back to on position
Oct 26, 2009 | GE Microwave Ovens
Powers on will not work
Check the breaker . A microwave oven should have a dedicated circuit plug a lamp in the oven plug in if it comes on you have another problem if it wont come on flip the breaker they can trip just enough that you cant see it is tripped flip it all the way off then flip it back on again see if it works. You might have to do this a few times even if light clock comes on it might be tripped just enough to not let enough power come through use a multi meter if you have one to check the current.
Oct 10, 2009 | Emerson Microwave Ovens
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JE2160 Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
