Question about Compaq Presario 700 470024-192 Notebook
Pc troubleshooting what are the general problems related to processor?
SOUND DRIVERS
Posted on Jun 13, 2008
Virtual mode exception error
7 Beeps: Virtual mode exception error
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Recommendation:
Troubleshoot the processor.
Troubleshoot the motherboard.
PCGuide TSX Troubleshooting the Processor PCGuide TSX Motherboard General Failures
Jul 09, 2014 | MSI Computers & Internet
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
When I open my IE8 - I got an error message (gpf) , I reinstall but the same problem remain.
Dear,
GPF gets its name from the dreaded "general protection fault" error in Intel x86 and related processors.
Refer to this page
http://www.gpf-comics.com/faq.php
Mar 10, 2011 | Microsoft Windows XP Professional SP3 Full...
Audio driver for cor2 2duo processor for windows 7 and processor is e4400 @2.0 ghz
sir prefer the link as pc driver is not related with processors.it is related with the mother board fo which you can use a website ........intel.com..........it will helpful..........
Nov 23, 2010 | Intel Computers & Internet
How much is the brand new mother board of acer 4520
Motherboards for laptops are generally not available to purchase. If you're having a problem with your laptop, send it to the Manufacturer and have it repaired or replaced.
If your laptop is out of warranty, you'll have to troubleshoot the problem down to which component is causing the problem. If the problem is related to the motherboard, you'll probably have to look into buying a new laptop.
Best of luck.
Mar 27, 2010 | Acer ASPIRE 4520-5141 AMD TK-57 1.9G 1GB...
My dvd writer cannot read DVD-Video Disc,but can write all dvds
Dear i have send a some information of your problem.
i have found some links please read this carefully.
and these links are help full of you.
Thanks.
The jerky pictures and poor sound quality are most probably caused by the IDE controller (the computer has an IDE hard disk drive) not being set to Direct Memory Access (DMA) mode, which allows the DVD drive to transfer data directly to the RAM memory instead of via the processor. The alternative mode is called PIO mode, which makes use of the processor. During a DVD movie, the processor's workload gets too heavy and the stress on it makes the video become jerky and the sound quality deteriorate.
The following article should contain all of the information you need to fix the problem.
DMA reverts to PIO - http://winhlp.com/node/10
First try playing different DVDs, preferably pressed DVDs instead of home-recorded DVDs, in order to make sure that you didn't just try to play a bad DVD.
Dell used to provide Recovery CDs with all of its computers, which it still does with its business computers. You can still buy the Recovery CDs as an option during the purchase of a home computer, but for the last few years, in order to cut costs, if the purchaser doesn't buy the CDs, Dell uses a recovery partition on the hard disk drive where all of the recovery files are stored. The recovery procedure is started from the command prompt, which you can open by entering cmd in the Start => Run box in Windows XP, and in the Start => Start Search box in Windows Vista.
It would be time-consuming and difficult to describe how to remove and reinstall the DVD decoder, so Dell's support suggested the easiest method of recovery from the company's point of view, and the worse method from your point of view. In any case, the problem might not even be software-related. It could easily be caused by faulty hardware. Sometimes, even though a drive can recognise and read CDs, a hardware fault could prevent it from recognising and reading a DVD.
That said, the cause of the problem is more likely to be software-related, so, I suggest using the Windows DVD Troubleshooter. To run it in Windows XP, click Start => Help and Support. Under Pick a Help Topic, scroll down to Fixing a problem and click on it. In the window that comes up find Games, Sound and Video problems, and in the right-hand window, click DVD Troubleshooter. To find it in Windows Vista, enter DVD Troubleshooter in the Search box of its Help and Support.
This MS Knowledge Base article provides other suggestions: How to troubleshoot common problems that may occur when a Windows XP-based computer cannot read a CD or a DVD - "This article describes how to troubleshoot common problems that may occur when a Microsoft Windows XP-based computer cannot read a CD or a DVD in a disc drive. This article contains several methods that you can use to try to resolve these problems." - http://support.microsoft.com/kb/321641
If you don't have the CD that contains the DVD decoder software, it might be difficult or impossible to locate. Usually, the DVD decoder software that comes with a DVD drive or PC has a condition of its licence that it can only be distributed with the DVD drive for which it is licensed, which means that it is not usually made available as a download. Fortunately, your PC uses Sonic Solutions software, which can be downloaded from Dell's Support site here: http://support.dell.com/.
You could also try using a free 30-day trial of Cyberlink's PowerDVD software from http://www.cyberlink.com/. It is generally regarded as being superior to Sonic Solutions software and the Windows Media Player. If you decide not to buy Cyberlink's PowerDVD and uninstall it after the trial period, it leaves behind the MPEG2 codec, which allows you to play DVDs using the Windows Media Player.
If the problem is hardware-related, you'll have to replace your PC's DVD drive. DVD drives/writers are currently very inexpensive, especially when compared to the prices of Blu-ray drives/writers.
Feb 19, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
661fx-m7, It is running ok for 6-10 minutes then pc shuts down with no warning. this can be when it is active or just sitting idle. any ideas please?
This is generally an indication of a processor error. It may be running too hot and stops working when it overheats.
Nov 15, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Difference betweeen intel celeron,core duo, mxx
Hello , Intel processors come in all shapes and sizes so I'll try to be brief by discussing only the ones that are current on the market. The market for intel processors are currently divided into 2 sides. One side if for single core processors while the other is for multi-cores. Single cores: Pentium 4, Pentium M, Celeron, Core Solo (Not very common) These cpus are single cores meaning that they only have one processor. They are relatively cheap compared to multicores. The difference between these are clock values, hyper threading, 64 bit support, and FSB. Pentium 4 and Celerons are cores found in desktops while the M is found in laptops. Single cores generally have low FSB but high clock speeds. Think of it as having a lot of water pressure but only a straw to dispense it. That's how fsb and clock values work. So single cores should provide you with a lot of raq power but they're not good at multi-tasking or jobs that requires it divide it's attention. Games like Crysis will be better with multi-cores because the pc has to generate so many different things at once while focusing on countless calculations and processes. the hyperthreading support does help the single core pentium 4s with multi-tasking but it's not as much as multicores. So if you're just looking for something with a lot of raw power. These are for you. Multi-Core Core Duo, Core 2 Duo, Core 2 Quad These are multi-core processors developed by intel. They are used in both laptops and desktops except for the quad. It's used in desktops only. The first 2 processors are dual cores while the last is quad cored. These processors have a high FSB rating and generally lower clock speed. So you have to be careful when looking at these. The high fsb means that the system does really really well with dividing and transferring it's processing power, but if you get a low clock speed then there's not enough power to begin with for the assignment. Example you may have a large hose but if you have low water pressure.. it's useless. That's why multi-cores are great for the modern pc user who multitasks way too much but if it's under 2.0ghz in clock speed. You should be worried about not having enough raw power to get you through intensive work. Multicores generally cost a lot more than single cores since they're relatively new technology. Btw the Core 2 Duo is faster than the Core Duo by about 7%. Meanwhile the quadcore is the ultimate in processor goodness but costs $400+. I hope these facts helped.
Jun 10, 2009 | Intel Computers & Internet
Cd rom wont start (code 10)
This device cannot start. (Code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Jun 21, 2008 | E-Machines Computers & Internet
USB Troubleshooting - Windows
Many problems relating to camera connection issues relate to hardware other than the Nikon camera. There are numerous compatibility issues between USB Controllers, motherboards, main CPU chips and different versions of the Windows operation systems. Below are some helpful links. The Microsoft web site has information regarding USB Troubleshooting for Windows 98, Windows 98 SE and Windows ME. http://support.microsoft.com/support/kb/articles/q263/2/18.ASP The Microsoft web site also has information regarding general compatibility between Windows and different USB controllers. Select "USB controllers" on the link and then find your USB controller on the list, if your controller is not listed as compatible or "logo" with your current operating system you may need to upgrade your OS, or work with alternate hardware. http://www.microsoft.com/hwdq/hcl/default.asp The Compaq web site has information regarding issues with their Deskpro 2000/4000 USB and Windows 2000. http://www.compaq.com/support/techpubs/customer_advisories/DG000117_CW01_0.html The Microsoft web site has information regarding issues between AMD Processors and Windows SE. http://support.microsoft.com/support/kb/articles/Q240/0/75.ASP One method for restoring USB functionality is to remove the currently installed USB Controller (from the Device Manager). Be sure to have the Windows installed disks available as you may be prompted for them. To accomplish this: Open the Device Manager (right click on "My Computer" and choose "Properties" Windows 98 and ME have a "Device Manager" Tab Windows 2000 and XP will have a button in the "Hardware" tab Click the "+ " sign next to item named "Universal Serial Bus controller" and highlight the "Unviversal Host controller" found beneth it. Once the item has been highlighted press "Delete" on the keyboard Refresh the Device Manager With Windows 2000 and XP choose "Scan for Hardware changes" from the "Action" menu. With Windows 98 or ME click "Refresh" If you were prompted for the install CD or to restart the computer there were definite driver changes made and any USB issues may be resolved.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Compaq Presario 700 470024-192 Notebook Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
