Question about HP 1040 Plain Paper Inkjet Fax
I have a new phone carrier(Vonage) and a new DSL modem from at&t. Prior to obtaining either, my fax machine worked fine. Now, I can't send or receive faxes..(Why)
    Scholar:
  • 79 Answers
This is a common issue with all fax machines that use a voip service. Basically, the reception and transmission features of the fax machine are not compatible with voip service. There is a modification that you can perform that usually allows you to avoid this problem, you must lower all transmission and reception speeds of the fax modem; this allows the data to be properly carried over the line without much loss or degradation.
-David.
Posted on Nov 04, 2010
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
Jul 20, 2009 | Computers & Internet
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have cable modem for my internet. I dont have any phone service
No. fax machines are ANALOG devices. Cable Modems, DSL, Vonage etc are DIGITAL.
Feb 11, 2009 | Canon FAX-L350 Plain Paper Laser
Phone line error comes up on the printer. cannot send faxes.
Do you have Digital, DSL, Vonage, or a Cable phone Line?
Fax machines only work on ANALOG phone lines.
Jan 05, 2009 | Lexmark Office Equipment & Supplies
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not...
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
Dave Grannas
Jun 01, 2008 | Brother FAX-575 Plain Paper Thermal
I am trying to connect my all in one HP J5780. I can't get the fax connected. I have DSL & I cintacted my provider and he was unable to help me. I get : Fatal error MSi.imagezoneeexpress. Can...
Do you have the adapter for DSL? If you don't have an adapter to get a standard phone signal, the fax machine won't recognize anything. The DSL connection is fine for your DSL modem that your computer connects with, but the fax machine, even in an all in one, has to have the adapter to be able to work. Most of the time you can obtain these adapters from the company you have your DSL service through. I am curious why they did not suggest this to you.
We have used DSL, and had to have the adapter to be able to use either a standalone fax machine or a standard modem.
May 13, 2008 | Office Equipment & Supplies
Fax machine is not working
is the phone line that is connected to your fax plugged into the slot marked by the "L" on your fax machine. if not make the correction. if so then plug in your phone into your fax machine labeled with a picture of a phone and see if you get a dial tone and be able to fax.
Thank You,
Mikey
Apr 06, 2008 | Office Equipment & Supplies
Have vonage fax and phone service
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:tunjiman23@yahoo.com.Mnay thanks
Apr 02, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
HP 1040 Plain Paper Inkjet Fax Logo
165 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
