Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 9100 will not power up
Turned off the machine after a tornado warning in our area. Everything else works power wise in the house but my Dell. There is a green light on inside the case.
  • mcbride7 Nov 09, 2008
    Kids dell 9100 died. Initally green light on power button. Cycled ATX connection @ motherboard and power cord. Started ok, (for me). 2 weeks later my kid brought the computer over with her for me to look at. Now no green power button light. Only single aux led on motherboard. Cycled connections to ATX supply, daughter board on front of computer as well as on MB, blew out .5 pounds of dust bunnies. Tested power-on microswitch, OK. Still dead. Shorted green wire on atx to ground wire to test supply. All drives spin up, all non-black wires have the expected 3.3, 5, 12 volts (tested with no diagram). But all are positive, should't there be some negatives? I will look that up but for now that is all the info I can give.
  • Anonymous Jan 17, 2009
    After a power surge computer was unresponsive but had front lights on.
    After turning off the pwer strip the green light on in case power button is unresponsive.
  • 3,940 Answers
Most likely the power supply have failed. Although the system is getting some power to the Motherboard (Flea power indication on motherboard) there are at least 5 different voltages the power supply provides for the system. Losing any one can cause a no power situation like you describe.
A standard ATX power supply should resolve (It is the 1st item I'd replace, both because it is the 1st point of failure and the cheapest to replace)
Here is one ATX power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182030
Posted on Jun 13, 2008
Update, My (kids) Dell 9100 has a 24 pin ATX supply. PIN 8 (PWR_OK) has 5 volts. All other pins have voltages as per pinout with the exception of pin 20 (-5 volts). There is no wire from the supply for that pin.
Posted on Nov 09, 2008
Swimmom626Did this solve your problem??
I am getting the same thing.
I have tested the switch and the Motorboard on the Switch, also the IDE Cable that connectes the switch to the Motherboard. And of course the Power Supply.
I am thinking it is time to change the Main Motherboard??
Posted on Sep 21, 2008
    Problem Solver:
  • 9 Answers
1. Can Dell Dimension 9100 work with 2x2gb ram? 2. I am trying to install Windows 7 on a refurbished Dell Dimension 9100. It has 2x2gb ram, 1 TB Hard Drive and I have Windows 7 32 and 64 bits + Palit...
Here is a link for upgrading to Win 7: http://en.community.dell.com/support-forums/desktop/f/3514/t/19356108.aspx
If you can't boot form the CD/DVD you have a problem with your CD/DVD drive. If you can enter the BOIS (setup menu) then your computer is working, just waiting for a device to boot from.
Mar 20, 2011 | Dell Dimension 9100 PC Desktop
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Flashing amber light
Flashing amber is normally a failed power supply. So replace the power supply ($50 to 100 depending on the size you buy) Recommend 500 Watt or higher.
www.newegg.com
www.zipzoomfly.com
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Dell Dimension 9100 - Motherboard & Compatible CPUs
Intel Pentium 4 Socket-T (LGA775) with Hyper-Threading or Dual-Core support, cache 1MB or 2Mb for 9100, or just 2Mb cache for 9150. I know of some of these machines having pentium D installed but I do not believe a Core 2 Duo is an option, whereas Dual-Core is. Good Luck!
Nov 11, 2008 | Dell Inspiron 9100 Motherboard - N4878...
Dell Dimension 5100 (D51L1) PC Desktop Logo
2,124 people viewed this question
Alun Cox
