Question about GE XL1800 1100 Watts Microwave Oven
My turntable quit turning. Can I fix it myself?
  • 613 Answers
Yes you can if it is just the "rubber band" drive...could be gunk too. Will come out thru back after taking cover off. If not the band could be the drive itself and just buy another as this can get expensive.
Posted on Nov 03, 2010
2 Suggested Answers
MicrowaveSvc
  • 9128 Answers
SOURCE: Turntable will not turn on Microwave
It's usually probably a failed turntable motor, but you should double-check the coupler, too.
We actually have the complete service & repair manual for this model at our site: http://www.microwavedisplay.cm/r930ak_aw_sm.pdf
You can order a new motor via Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 11, 2008
My microwave turntable stopped turning but the microwave still heats up and works, otherwise.
You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
Dec 24, 2015 | Microwave Ovens
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
Frigidaire microwave
Probably the turntable motor has failed.
Jan 10, 2018 | Microwave Ovens
Smh9187 turntable quit turning
1) the cabinet need to open for repair the small motor can be defective.test it see the diagram
2) test the plastic drive coupling+ring and roller assembly if is working properly , test and fix it.
see the diagrams and pictorial
God bless you
Jul 17, 2012 | Samsung SMH9187 Microwave Oven
GE Spacemaker microwave turntable no longer turns. Microwave still heats, but turntable has stopped working. What are likely causes? And is this something I can attempt to fix myself?
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Jan 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
GE Spacemaker JVM1533WD turntable sometimes works, mostly doesn't
The part with the three rollers that holds your turntable needs to be replaced if you want it to turn. That plastic and those rollers get cooked over time like everything else. The microwave is designed to basically cook with the moisture in anything placed inside the microwave. Those rollers have probably become warped enough so they don't roll properly when heated and that is why they do work somewhat after a night of nonuse. You may be able to find one at a local repair shop for almost nothing. Those parts are pretty generic. Even at a garage sale or flea market. Other than buying from a local dealer you can go on the internet at www.mwoparts.com and get any part for the microwave. Good luck and God bless you.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Feb 10, 2008 | Microwave Ovens
GE Spacemaker XL 1800 Turntable malfunction?
You can find helpful exploded views and buy the replacement turntable motor at http://tinyurl.com/gv383 Need safety tips? See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM2070 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
229 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
