Question about Siemens WIQ1633 Front Load Washer
Siwamat XB 1060 - water comes out of the bottom of the machine when I put on a wash. Is there a filter that can be cleaned?
SOURCE: Washing machine
f63 shoes on machine
siemens e 12 46 is the machine only 4 months old is there anything i can do befor i call an engnieree
Posted on Mar 02, 2008
kjmac
  • 97 Answers
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Posted on Jul 25, 2008
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
  • 180 Answers
SOURCE: Hello! Our Bosch-Siemens clothes washing machine
Make sure you use high efficiency detergent.  The front load machines take a special kind of detergent to make them run smoothly.  Check your drain hose for clogs, and clean the pump again.  If none of these fix the problem, you will probably need to replace the pump.
Posted on Nov 07, 2009
  • 215 Answers
SOURCE: It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Posted on Feb 17, 2010
Testimonial: "that seems to have worked fine thankx"
I have a siemens siwamat xb 660 washer machine. how can I find a user manual?
Dear Alberto,
If you are in the U.S., try typing the model number into the web-site called: "Searspartsdirect" in the appropriate space.
If this machine is sold in this country, you should find the option to order or copy a user manual at that site.
God bless your efforts.
Sep 21, 2018 | Siemens Washing Machines
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
Siwamat xb 1060
Could be the transformer inside the machine..
Mar 31, 2014 | Siemens Washing Machines
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
Error code E320 appears and the machine has failed with this code
Go to the very bottom right of the washing machine, open up the flap; there is a round filter. Open up the nozzle and put a towl down underneath- once the water has stopped coming out, twist the whole filter until it lifts out. Clean this (there may be money and fluff in here) with water. Put it back in. Put the washing machine on a high temperature wash without anything in. This will give it a good clean, and get out any residue from products used. It should work okay after this.
May 10, 2011 | AEG Lavamat 72640 Front Load Washer
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
Washing machinewont empty
Pump shot or blocked
Drop the drain hose into a bucket , if water comes out reasonably quickly it is not an object of clothing that has gotten inside the pump so it could be a coin
Take out the filter on the bottom of the machine by unscrewing it and look at the impeller of the pump to see if a coin has become lodged there
Oct 27, 2009 | Washing Machines
My siemens washer will not pump the water out or spin
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Washing machine
hope this helps
Jul 22, 2008 | Washing Machines
Siemens WIQ1633 Front Load Washer Logo
614 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Marvin
Marvin
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
