Question about Canon PowerShot SD1100 IS Digital Camera
Flash of my Canon PowerShot SD1100 IS not working at all
  • cac1998 Nov 03, 2010
    never dropped
    Filmmaker:
    Uploaded 5 video answers.
  • 31 Answers
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Posted on Nov 03, 2010
SOURCE:
  • 38 Answers
SOURCE: canon powershot sd1100 water damage..how can i
You really can't....however, there is a very small chance that it might work but you need patience though. First you need to take the battery and the casing off in order to expose the circuit board. Secondly if you can find a dehumidifier, you should run the dehumidifier and place the camera in front of it for 72hrs with no interuptions. Lastly, put the camera back together. Hope this will help. If not, the circuit board has short circuited itself and there is no possible way to replace any components.
Posted on Jul 08, 2009
t00nz
  • 4738 Answers
SOURCE: my canon powershot SD1100 IS camera lcd screen
You may have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. Press the DISP button once with the camera turned on to see if that corrects the problem. If this doesn't correct it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jul 31, 2009
  • 69 Answers
SOURCE: Cannot download pictures to computer
check your device manager on the computer to see if your if your usb driver are loaded and have no conflicts, u could also have a bad cable don't load the camera software on to the computer if you did uninstall the software from the PC and then plug the camera in and let windows recognize the camera if this does not work change the cable your using, GOOD LUCK
Posted on Sep 21, 2009
  • 102366 Answers
SOURCE: Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
SOURCE: Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Posted on Sep 01, 2010
How do I turn off the flash option on a Canon SD1100 IS
Press cursor-right (marked with a lightning bolt). Use cursor-up/down to select the lightning bolt inside a circle with a diagonal line through it).
Full details are in the "Using the Flash" section of the manual (page 64 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/5/0300000755/01/PSSD1100IS_IXUS80IS_CUG_EN.pdf
Feb 27, 2011 | Canon PowerShot SD1100 IS Digital Camera
Turned on camera (Canon PowerShot SD1100 IS) and was told that the card was locked! How did this happen and how can I unlock it?
Aug 14, 2010 | Canon PowerShot SD1100 IS Digital Camera
Canon powershot sd1100 need to turn off flash
Press the lightning bolt button, then use cursor-left/right to select the lighting bolt in a circle with a slash through it. Full details are in the "Using the Flash" section of the manual (page 64 in my copy). If you need a manual, you may download a copy from here.
Nov 09, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
444 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
