Question about Garden
Won't turnover start fire ? ? ? ? - Garden
    Filmmaker:
    Uploaded 5 video answers.
  • 31 Answers
One thing to check it your spark plug - a mower wont start with a misfiring plug, second check your fuel filter - it could be clogged up - some people say wash them out with gas or just simply replace them...if neither of these help it may be a fuel line...if you can provide me with exact model I will be more than willing to help you further...
This Might help you some - http://www.youtube.com/watch?v=kAdhaaY9HMQ - for spark plug
http://www.youtube.com/watch?v=wRHmdtLg99Q - for fuel filter
Posted on Nov 03, 2010
Car won't start when hot.
Have you checked to see if you have power to the starter post when the key switch is in the start position ?
Jul 06, 2013 | 2002 Hyundai Santa Fe
Engine won't turnover
It sound like the starter solenoid that forces the starter gear onto the flywheel, you need to replace the solenoid unit.
Mar 30, 2013 | Rear Right Window Regulator & Motor for...
I have 97 yzf600r I push the start but won't turnover with/without choke on?
Did u pull the gas tank look under there is a shut off valve make sure it on .it sounds like u ant getting gas .so check that hope it helpd
Jun 03, 2012 | 1997 Yamaha YZF 600 R thunder cat
2009 Heritage Softail engine won't turnover
Is the run/stop switch on the right handlebar in the "run" position?
May 19, 2012 | 2009 Harley Davidson FLSTC Heritage...
Engine won't turnover. No spark
Bad crank sensor or main ecm needs repair.
May 16, 2012 | 1993 Jeep Grand Cherokee
When trying start it won't turnover and oil is
Rings! Don't know if this is 2 cycle or 4 cycle engine.If it is a 4 cycle engine you shouldn't have crankcase oil on the spark plugs.If it doesn't turn over,how is oil getting on the spark plugs? At any rate,I'd check for cracked ring or rings.
Apr 06, 2012 | Yamaha Boating
It won't start
You need to find out if you have fuel pressure to the fuel injectors, and if not you may have a bad fuel pump. If you do have fuel pressure, then check if the spark plugs are firing. If they are not there could be a bad sensor, like a crankshaft position sensor.
Dec 31, 2011 | 1999 Acura SLX
1994 CONCORD NO POWER TO FUEL PUMP, NOT FIRING AND DOES TURNOVER, REPLACED CRANK SENSOR AND CAM SENSOR, TRIED DIFFERENT RELAY FOR FUEL PUMP-STILL WON'T START?
NO POWER TO FUEL PUMP......CHECK ALL IN LINE WIRING
NOT FIRING... START WITH COIL PACK, DIST CAP ETC...PLUGS/WIRES??????
"HOT WIRE" (DIRECT W/ FUSED JUMPER) TO FUEL .PUMP....NO - GO,,,BAD PUMP
Oct 09, 2011 | 1994 Chrysler Concorde
Cranks but wont turnover
I don't understand this ... "cranks" is the same as "turn over". How can it crank and not crank (or turnover and not turnover) at the same time?
I think you meant to say it will crank (or turnover) but will not fire or ... it will fire but not start.
This kind of compaint point to ignition or gas. You may be 'out of time' or your plugs are fouled. Depending on the actual method of firing the plugs, you may have a 'points' problem or a sensor out of adjustment trouble. There is also that troublesome "kill switch". Are you sure the kill switch is in the Run Position???? Go check it anyway!!!
In the gas department, do you have gas? Can it get to the carb? Dirty fuel filter? Valve Open?
And as a last suggestion of where to look, are the safety interlock switches ok? The one that is on the kick stand that will not allow you to start if you are in gear and the stand is down?
If you are still stuck, it may be time for a professional tuneup at your Honda Motorcycle Shop.
I hope this helps you. Thanks for your question at FixYa.com
Please vote
If I can be of further assistance, post a comment to this question
thanks
Dec 20, 2009 | 2001 Honda CB 750 Nighthawk
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
