Question about Grundig GF70-600 TV
Grundig tv thanks ronpar....but the remoteworks the tv ok..its just i have moved to a different part of the country and need to retune the tv to local transmitters and cant access the auto tune or manual tune feature , to allow me to co this..any ideas?..thanks
  • 27 Answers
On most tvs you go to menu then setup then if you have cable go to where it says (air and cable) select cable or if you just have a anttania select air then go up to where it says autoprogram then push to get you channels in you should be abale to use the remote or the front panel on tv if this don't work give me the make and the tv name. hope this helps if not let me know thanks randall
Posted on Jun 13, 2008
  • ron park
    ron park Jun 13, 2008
    and again if you can not get your remote to go to the menu you will have to try other codes thats made for that tv if not like i said before all fuctions may not work with a certion code thanks randall
I need an update for a 18.5 lcd tv.model no:19-229 I can find it anywere...thank u
Howdy James Andrew,
Appears to be a UK
Tesco Technika ... This is a (mostly) USA site
So our cyber-wisdom gets a little sparse on UK "updates"...
(but we try).
(so... "retuning info... UPDATE": is what U're after??).
Try these sites below...!!
SERIOUSLY ...
a local search ought to work better for YOU.
Good luck...!!
TESCO LCD- 19-229 USER MANUAL Pdf Download. - ManualsLib www.manualslib.com/manual/723669/Tesco-Lcd-19-229.html
Page 1: User Guide. HD Ready LCD TV with Freeview, DVD Player & USB Media Player User Guide Model No LCD- 19-229.
2 Retune How to retune. Retuning your TV is a very quick and simple process. We recommend that you retune every few months to ensure you are receiving the very latest TV and radio channels that are broadcast. 1) On the remote control press [MENU] followed by 8 - 8 - 8 - 8 (so the number 8 button four times) 2) The First Time Installation menu will appear. Press [OK] and tuning will take place. For help and support regarding the digital switchover, please contact Digital UK: Telephone: 08456 50 50 50 (calls charged at local call rate, approx 3p per minute daytime or 1p per minute evenings from a BT landline) Digital UK website: www.digitaluk.co.uk
Digital UK Home
Carnac the Magnificent
Feb 05, 2017 | Televison & Video
Is there a code to make my tv usable outside the US?
Tv should work fine outside US providing power supply is correct, I have taken my small tv all over Europe with no more than a converter plug to suit the different countries. You will need to retune tv for the country you are going to, also note that dvd's and bluray are coded and nneed to be played on machines of the correct code.
Jan 04, 2016 | Samsung Televison & Video
I cannot retune my grundig TV . On the menu it does not stop on the correct option thanks
Main system control memory IC fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2015 | Grundig Televison & Video
Have just moved house .....have retuned tv ....but cant get any BBC channels
Automatic scan cannot detect the BBC channels, possibly because they are too weak in your new location. It should be possible to add channels manually by using your remote. The setup function of your TV may give you the option of adding channels manually
Oct 14, 2012 | Grundig Televison & Video
Grundig tv retune
What is the exact model number to your Grundig TV
Sep 08, 2012 | Grundig Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Retuning not holding memory
Hello
The memory IC in the circuit of your Grundig is not working. There are two resons for this fault. The first one is, of loss of voltage to that IC. This IC is a non-volatile type [that is, even though the supplied voltage goes OFF, the memory cells inside it will hold the last position memory, will not loss it]. This is a very samll IC, of 8 solder termiminals and can be located very near to the main system control IC. It is drived and memorized by main system control IC, by Serial Data, Serial Clock signals. Fault to this IC is quite normal to most of the TV, irrespective of brand and model number. It is very cheap to buy too, and can be bought from most of the electronic sparepart selling shops at your town. It has a number printed on it, must be noted before buying a new one. In some models of Grundig Tv, this IC will be an SMD [Surcace Mount Device] type. In others, it will be of norma DIN [Dual In Line] type. If the IC soldered to your tV is of fromer type, it cannot be replaced by normal soldering techniques. If it is of second type, it can be desoldered out and can be replaced with a new one. Look whether the type fitted to your TV's circuit is of second type [DIL]. If so you can do the work by yourself at home, provided you must ahve a concept of desoldering and soldering; a good quality DC soldering Iron, and an antistatic desoldering pump, and a very good quality digital multimeter, like Fluke or so. If the type is SMD, no other way other than get this set repaired by any well equipped service center of by the Authorised Service Center for Grundig at your town.
Check the board and confirm the type. Use of a hand glove is recomended when repairing this system control section, as the main system IC is very static to external voltages; even the voltage generated at the tip of human fingers may damage them. There is no other fault with your set, except this IC. The component is cheap to buy, but I don't have an idea about the service charge at your country.
If you haven't enough knoledge and skill to do the work, just get this set repaired by it Authorised Service center.
If you want anymore assistance from me, feel free to get me by Fixya. OK.
Sep 26, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Cannot get ITV1, ITV2 or CH5 anymore after retuning. Connected to outside aerial
Go in menu,Picture setting go down to reset,to back to factory seting.Go to retune or CH. again will get everythings back.
Jan 12, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
264 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
