Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Mother board dosnt powered on smps
New tested smps replaced but problem remain same,
tell me some tips for repairing such type of problem.
i hve allready tried :- CMOS battery, cmos recovery, CPU (change), RAM etc.
Change your power cable,then ur mother board I/o controller chip bad conform so service your board
Posted on Jul 02, 2008
  • 3 Answers
Whatz the problem dear..???
reply
Posted on Jun 13, 2008
Dell ps5022 2df how to test
remove smps and attach power chord to smps and sort green and black colored wire if fan works den smps is all rite if not den its faulty if smps is working den problem is with ur mother board
Jul 31, 2014 | Dell Computers & Internet
My smps is working, but my power is not coming to the mother board
Replace the power supply or have it tested.
Amazon com bestec atx 300 12z You can get a replacement pretty cheap. Most all power supplies can also be tested - Bestbuys geek squad or a small computer repair shop should have the means to test it.
Feb 23, 2013 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Board do not show any sign of power starting
test all power and data leads that attach to your hard drive,
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need power and data to travel through every working device and to have an end for a computer to be able work
check the ram modules have a secure dust free seating
check your computer ram and cmos battery to make sure they have dust free secure seatings and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope this helps
Aug 02, 2012 | Computers & Internet
I'm looking for a power supply for a sinotec 32"LCD tv. my tv was damaged by lightning
The replacement SMPS must confirm to the voltage/current sepcifications required for the TV and so it is best to get the same type from the dealer.
However if you are trying to get a universal type the output voltage and the protection should be of correct value or else it can further damage the motherboard.
finally if this was a lightnening strike please confirm if the mother board is working if not investing on a new SMPS should be reconfirmed.
Tips on SMPS repairs click ON:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 20, 2011 | Element Electronics FLX-1910 19 in. LCD...
How to replace the plug were the ac power get connected on a PSLV6U-01F009 some people tell me that I hve to replace the whole mother board.
If your problem is just the wirings/cables then you can get those on computer repair shops at a very cheap price. So better visit one and bring your computer with you so they can replace it themselves.
Thanks for using fixya!
May 31, 2011 | General Computers & Internet
Ive had this bluray player for 2 years and it was working fine, then one day i tried to turn it on and nothing happened. i checked if the fuse was blown but i appears to be fine. so there is no power...
hi,
there is possibility of two complaints.
1, The SMPS power supply fault
2. the mother board fault.
if the SMPS is faulty the you can rectify the problem. If it is with the mother board the you have to contact the manufacturer .
First of all you have to check the SMPS ( switch mode power supply). you have to check the voltages at it secondary stage. 5v, 12v, etc
switched-mode power supply (switching-mode power supply, SMPS, or simply switcher) is an electronic power supply that incorporates a switching regulator in order to be highly efficient in the conversion of electrical power. Like other types of power supplies, an SMPS transfers power from a source like the electrical power grid to a load (e.g., a personal computer) while converting voltage and current characteristics. An SMPS is usually employed to efficiently provide a regulated output voltage, typically at a level different from the input voltage
for checkin the SMPS voltaes you need a multimeter. And check the voltages at it secondary stage
Added the inside view of BD 1600
if there is no outputs from the smps then you have to replace the SMPS drive STR ic near the big capacitor. Also ty to replace the OPTO coupler ic. y have to check the all resistors near the ic.
Remember one important thing that the capacitor can hold charge for some time even if you disconnect the power. so after removing the power. remove the SMPS very carefully. discharged the capacitor using a bulb.
i have also added a video for SMPS working for you reference will hep you for repairing your one
ok
Apr 07, 2011 | Samsung BD-P1600 Blu-ray Disc Player
CPU does not turn on..everything is plugged in..power cord is plugged into a working socket. what are my options?
its 2 cable that need to be plugged in from the power suppley, the wide cable and a 4 stick cable. both to the mother board. also you need to connect the fan cable to the mother board. how do you know that the processor doesent start ?
Oct 26, 2009 | Computers & Internet
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
