Question about Master Lock 5400d: Portable Select Access Key Storage Lock
How do you set the combination? - Master Lock 5400d: Portable Select Access Key Storage Lock
  • 56 Answers
Open the lock with the existing combination. Inside the flap, you'll see a small chrome lever. Push the lever to the left (as you're looking into the box) and **** it up into the offset slot. This puts the lock into the "learn" mode. Select your new combination and rotate each wheel until the numbers line up at the opening index. Flip the lever out of the "learn" position, and back into the "home" position.
Test your new combination several times, before closing the door.
Posted on Jan 05, 2011
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA Lock® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
STEP 2
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Set combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
How to set Samsonite combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Sep 26, 2009 | Kwikset Locks & Locksmithing
Combinations and Permutations
You can enter combinations and permutations.
If the order of the selection matters (ie. 1st, 2nd, and 3rd place out of 40 contestants) use permutation. Enter:
40{shift}{nPr}3 and then [=] for your answer set (=59280 possible ways).
IF order doesn not matter (ie. a team of 3 from 40 possible members) then it is a combination. Do the same as above, but substitute {nCr} for {nPr}. (= 9880 possible ways).
For your question: a three-digit set, selecting from 0-9. There is no specified order, it is a combination. The total n=10 (there are 10 digits in the range 0-9) and you are selecting 3.
so.... 10[nCr]3 with give the number of possible combinations.
Feb 16, 2009 | Casio FX-115ES Scientific Calculator
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
170 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
