Question about Fujitsu Siemens AMILO Pro V7010 Notebook
Dead, external power supply ok
A/c power supply ok,computer dead, would like to check the input socket which seems to have caused many problems, removed all screws etc but still unable to lift the key .pad
  • 12 Answers
The way I lifted the keyboard was to insert a small flat blade screw driver at four points at the front of keyboard where there are metel tabs one at front of FN key and one to left of space bar then the alt to right of space bar and the downward arrow. insert screwdriver in and back towards the front and gently lift.Hope this helps
Posted on Sep 26, 2008
Several keyboards with same prob. Willnot power up.Adaptor ok.Any suggestions or other issues to look for cassio 691 and 611
Power input sockets come away from the pcboard. Is the polarity of the power supply correct.
Nov 25, 2016 | Computers & Internet
V7010
have you gone through the manual ..........
Jun 26, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
What are the parts of a motherboard(P4)
This sounds like a "homework" question for an Introduction to Computer Hardware class.
First, there is a socket for the Intel Pentium 4 ('P4') CPU chip.
Second, there are sockets for RAM.
Third, there are sockets for power from the power-supply.
Fourth, there are power-leads, to send power to the various fans.
Fifth, there are internal connectors (speaker, on/off button, reset button, front-panel lamps).
Sixth, there are external connectors (keyboard, mouse, serial port, parallel port, USB port, FireWire port)
Seventh, there are external sockets (microphone input, line input, line output) for speakers & microphone.
Eighth, there are sockets for the video-adapter, and for other optional add-in cards (TV card).
Tell your teacher that you got help from the Internet.
May 25, 2011 | Computers & Internet
My lenovo desktop computer is not starting up
If it does not make any signs ..I mean no noise and no light on ...it usually means it is a power issue or a dead mother board..I would go for a power issue in this case and check the cables..and the motherboard connections with the power supply ..Also check the power switch in the back (general switch ) if it has one .
Than if you check the power supply with some other consumer or a measurement tool ..and it seems to be OK .check some voltage on the main board.and see if it has power..usually if you can not seam to have any power it may be dead..but in this case would give you an amber light ..
If you got another computer around you can even make some switching of parts and try to identify whats is wrong ..If all the parts seem to work in otehr computer ..than it is the motherboard and you need to get a new one that will support the devices you have in this one ..This way you will not be forced to buy ram memory or cpu ..just buy a motherboard with same socket for cpu and same slot for ram memory ..and will work ..
Nov 16, 2010 | IBM Lenovo ThinkCentre M55e PC Desktop
My tv auomatic off after 1 mi
1]...Please check that the sleep timer function is not set;
2]...Some tv's have a count-down timer & switch off if there is no signal input, either from the tv aerial, or av input;
Please check that the aerial is plugged in to the correct socket on the rear of the tv; test the aerial in another tv, to make sure it is working ok.
3]...It could be a problem with the remote/teletext panel?
for example, switching unexpectedly to standby, or changing channels unexpectedly?
4]...It could be a power supply fault;
for example, switched mode power supplies (SMPS) can cause problems; this could also cause the set to switch to standby mode.
PLEASE NOTE:
If the unit still switches off after 1 minute, even after checking the tv aerial is functioning properly, & is connected to the tv unit aerial socket ok, & the source is set to the tv aerial, then this could be indicative of an internal fault.
TV sets contain extremely high & very dangerous voltages, even after the tv has been unplugged from the ac power socket, on the wall, which could kill you!
FOR THIS REASON, & FOR YOUR SAFETY PLEASE DO NOT attempt to open or repair the tv unit yourself, unless qualified to do so - please take it to the tv repair shop;
only qualified tv engineers should attempt to carry out tv repairs.
I hope this information was helpful for you.
Thanks,
Steve.
Oct 01, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
2003 chevy suburban lost power r/side front door.
CHECK THE WIRES THAT COME OUT OF TH A PILLAR INTO THE DOOR.ONE OR WIRES ARE BROKEN
May 14, 2009 | 2003 Chevrolet Suburban
How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Oct 22, 2008 | Computers & Internet
Computers & Internet Logo
284 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
