Question about GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
Defrosting Problem Hi, We have a monogram side-by-side built-in refrigerator. Fresh food side temperature goes up(warmer) and freezer side goes down(colder). We have to open both doors, turn it off, take out all food and wait for about 2 hours. Using hot wet both towel to warm the panel between freezer and refrigerator will accelerate the defrost process. We have to do same work every 3-6 months. Please let us know how to solve this problem.
    Sergeant:
  • 229 Answers
We have a fridge that does the same thing. We simply shut it down for about an hour when we notice the fridge building up frost. By not waiting until it gets too thick we are able to get the frost down without shutting down, removing all the food, and using extra heat to defrost it. We have to do this about once a month, but it saves a huge mess. By the way, a refrigerator that is self defrosting, such as the one you have shouldn't have to do this, but unfortunately the only thing to do is an expensive repair or replace the fridge.$$$$ Good Luck
Posted on Nov 23, 2008
    Sergeant:
    Champion:
  • 283 Answers
On 'standard' systems, a small timer turns off the compressor every 8 hours (in most ref's) that it runs, and turns on a heater in the freezer's evaporator coil. The timer remains in the defrost cycle for 20 minutes or so, during which a small defrost limit thermostat turns the heater off when the coil's temperature reaches a preset temperature. This temperature is 45-70 degrees F, depending on refrigerator design.
When the defrost system fails, it causes the evaporator coil to continue accumulating frost until air can't get through it to do its job of cooling (transferring heat from, actually) your groceries.
By the time you see frost in the freezer, coating the back wall in most designs, the coil will be clogged with frost, and in need of attention.
First, ensure that the freezer fan's running. Fan failure can also cause coil frost-up, so this is the first test. (Be aware that some refrigerators have a fan switch that turns this fan off when the freezer door's opened. And some new refrigerators' ADC computers switch and vary the speed of the freezer fan - these can be very tricky to diagnose).
If it's *frost* and the freezer fan's running, you have a defrost problem, usually caused by one of 3 components: timer, heater, or defrost t'stat. The good news is, if the frost is evenly coating the coil, the expensive stuff's OK - no Freon leaks or restrictions Thank you.....
    Genius:
  • 3,422 Answers
HI,
Did you try unpluging all the cords from back for 3 hours and then plug it back in.This is know as a hard reset.
Posted on Jun 13, 2008
  • Priya darshan Jun 13, 2008
    The first
    thing to check is the overall internal refrigerator temperature (see
    the Appliance Accessories section for a refrigerator/freezer
    thermometer). The proper temperature should be between 35 and 42
    degrees.
    The defrost timer is behind a cover
    near the light, The timer puts the fridge in defrost ever 6 to 8 hours.
    If the timer is bad it will stop the cycle of defrost and cause the
    freezer and the cold food section to warm spoiling the food and
    increase the freezer temp. Try turning the timer screw clockwise until
    you hear the fridge compressor stop. If after this listen for a
    crackling noise that will be the sound of defrost taking place. If
    doing this starts defrost, you will need to replace the timer.
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram side by side freezer is at -5 fridge at 56 fans running evap even frost pattern, damper is open when the door is open cold air comes from the freezer when closed does not get cold
If you are showing a frost pattern iside the freezer and higher temperatures in fresh food compartment that is a sign of defrost failure. What is happening is the airflow to the fresh food section is being restricted by a large blok of non defrosted condensate behind the rear pane you see the frost pattern own. I am sending a manual if you like to follow along and ask questions but as I see from your discription this is what most likely happening. Your model does defrost cycle through the motherboard and has no defrost timer. So the most likely cause is you Defrost heater or defrost thermostat are defective. Here is the heater and instructions on how to test heater Click Here=> WR51X322 Heating Element and Defrost Thermostat=> WR50X10088 Defrost Thermostat
Here is the service manual=> GE Monogram Refrigerator Service Manual
You can find those two part numbers here also=> WR51X322 Defrost Heater
and Defrost Thermostat Here=> WR50X10088 Defrost Thermostat
Should you have any questions I will be here to assist you or on my sites, Thank You Sea Breeze
Also make sure none of the lower vents are closed inside fresh food compartment that will also restrict airflow. Manually defrost ing the freezer will give you about another week to resolve this problem should it turn out as defrost problems. You will need Adobe Reader to open the manual I sent you=> free download.
Oct 15, 2011 | GE Monogram Side by Side Refrigerator
Do you know the fresh and frozen food capacity for this GE refrigerator z1sw42emc
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Dec 26, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Have a GE monogram built in side by side (2001 model)and some of the food in the refrigerator has ice crystals or freezes, can't control temperature too well. any idea?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
GE Monogram freezer will not stay cold enough
This sounds like you freeezer is not defrosting properly causing foods not to freeze rapidly and possibly causing the fresh food section to remain warmer than normal. I think it would be a good idea to unplug and remove the rear panel in the back of your frezzer to examine just what is going on. Hopefully the defrost element part number WR51X322 is not defective. We also will need to inspect the mother control board below your refrigerator and in-closed in a case that covers the board. All defrost is done by this board part number WR55X10560 Look for burn marks and signs of heat damage. If found the board will need replaced. You also can contact me at appliancepartsse@yahoo.com and the parts can be found at these links. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator Logo
189 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Jim Akins
