Question about Watches
Tag Heuer watch. Stopped working a few weeks ago. I changed battery. Didn't work at first but then did when sufficiently tightened case. Today it stopped working again. Second hand looks 'stuck' it is 'twitching' very slightly. No obstruction, nothing is bent - it did this before as well.
  • rcoomber977 Nov 03, 2010
    Brilliant - thank you
  • 1,711 Answers
This is a battery problem different brand of batteries they have the same code but they have a very small difference just portion of millimeters in the thickness. This some equipment using these batteries is not a problem however for watches this tiny difference matters since the contacts are not stable that is why fist was working and now not. So either you have to find other brand batteries same size.
Posted on Nov 03, 2010
  • espressonist
    espressonist Nov 03, 2010
    You can try first to move a little bit the battery top metal contacts and you will see that the watch will work without cover. Try put back the cover and this might work if it repeated then you should try other brand of same size battery.
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Mar 25, 2010 | Tag Heuer Automatic Chronograph Series...
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
I need the manual
I can solve your problem as I had the same one on my Tag Heuer 2000 Classic Multigraph WK111A.BA0331, just recieved last week. A few minutes ago I was finally able to get the company to send me a PDF file with the instructions, and you definitely need them. Email me your address and I will send you this file with my comliments.
Feb 18, 2010 | Tag Heuer 2000 Classic Multigraph...
Tag heuer f1 2001 has stopped
Don't open it or it may not be waterproof any longer, I'd say almost certainly it's the battery, so you need to take it to a repair center to have the battery replaced
Jun 17, 2009 | Watches
Self winding does not work
Could be its just not a good quality watch, you didn't state the make. if its an invicta, then tbh, its to be expected they can be very hit and miss. You can buy demagnetizer for about $10, £6-7. Things like speakers, computer monitors or strong electrical field can magnetize a watch making them perform very inconsistently.
Mar 20, 2017 | Tag Heuer Link WJF2112.BA0570 Wrist Watch
Water ingress
Peter,
I am not a Tag expert, but do have quite a bit of experience with Rolex and Tudor watches. Without a shadow of a doubt, the top three water egress points are:
  1. Crown
  2. Crystal
  3. Caseback
I would check the recent service receipt to make sure they replaced the crown gasket (or o-ring). If you know for sure you have submerged or wet the watch without the crown being tightened in the past, the problem is likely a mis-aligned or missing gasket (o-ring). Also, have your watchmaker take a look at the crystal and caseback. I had a watch serviced once -- and the watchmaker forgot to tighten the caseback. Thankfully, no water got into the watch.
I hope your results are satisfactory.
Regards,
CharlieJ
Nov 17, 2008 | Watches
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Need extra bracelet lings for a Tag Heuer Indy 500
Hi.  I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife.  I'm a smaller man and had to take out 3 links.  I'd never sell this watch so if you would like them...just write. croscow@comcast.net
Charles Roscow Silver Spring, MD
May 02, 2008 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Moisture
After 5 years all of the case parts must be replaced i.e.,gaskets and crown then the watch must be pressure tested. anyone who is autherized woulod know that. contact Tag to have the matter resolved
Jun 05, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Watches Logo
200 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
