Question about Palm Treo 755p Smartphone
Screen problems I have had my phone for 1 month now and every once and a while the screen will go black in the middle of a call/internet/ anything I'm doing. The only way to get the screen back on is to take the battery out and restart the phone. Any suggestions?
    Problem Solver:
  • 8 Answers
I have personally had every Palm Treo ever made. I am also currently a 755p user and this is my second 755p that I have owned.
The problem that you are having is a common one and one that I have seen from every Treo that I have owned. I have found though that many of the problems that people have with their Treo's is that they do not turn them off and on again on a regular basis. I have found that if I power off my Treo for a few minutes in the morning and again mid way through the day that I have a lot fewer problems then ever before.
This is about all the help I can give for the problem that you are having, I have always loved the Palm platform Treo's, but there are a lot of problems that come with owning one and as a multi Treo owner I have learned to just live with them and try new things to see if they will work, but the suggestion that I gave above has helped with my screen blackouts and made owning my Treo's much nicer then before.
Hope this helps,
Glenn
Posted on Jun 22, 2008
Samsung galaxy music will not turn back on again this happened about 2months ago and I'm very disappointed
Hello Debra, from what you,ve just said it appears your phone is in "Safe mode". And once that happens, you"ll be unable to use apps on the phone. So here's a quick tip to what you can do(if you can) or otherwise give a technician.
First: check the down volume button to see if it's constantly pressed down on its own. Cos that's where the problem starts. If it's not then move to step two. If it is, then guess it's not what you can do. You"ll have to give a technician in a repair centre to have the button changed/replaced.
Secondly: remove the battery, and try to fiddle i.e keep pressing the up and down volume buttons for few seconds before putting back the battery and power on. If same issue occurs then am afraid you'll have to take to a repair centre.
Drop your result afterwards.
Apr 23, 2017 | LG Shine KE970 Cellular Phone
Phone seems to work, but has a blank screen
i think its display problem.. check the display once... or take a new dispaly
Nov 20, 2009 | Nokia 6300 Cellular Phone
My LG Lotus main display just stopped working in the middle of a text I have tried turning it off and taking out the battery if I filp the phone open the screen lightens but doesn't display anything
Take it to a sprint store that has a repair center (check Sprint.com and click "Find a store on the top right corner for which store in your area has the repair centers). They will fix it for free or for $35. Sprint is the only national carrier to support instore repairs, and I praise them for this.
May 30, 2009 | LG Lotus Cell Phone
Samsung Tocco Buttons not working properly
i had the same problem but my problem was the touch wasnt working!!! inside the screen case there is a tiny black square it has summat 2 do with tht coz my touch stpd working and it was all coz of tht!!! i had 2 buy a new cover 4 my fone it also powers tha buttons so i wud get a new case ( ps.... not a protective case!! lol an actual body of it lol) hope i helped
May 03, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Ethernet Cord for Router?
I want to tell you that how can you get your password back or reset your wireless password.
1. Work on your wired computer which is connected with the netgear router using ethernet cable
2. Make sure on the rear side of your netgear router you can see four ethernet slots and one internet slot.
3. One internet slot is only for your ISP modem and rest of the four slots you can use any computer to connect with that using ethernet cable.
4. Click on start - Run - then type in "cmd" press enter and you will get black screen. under the black screen just type "ipconfig" you can see some information on your screen search for default gateway numbers.
5. Once you get default gateway open IE and type those numbers without anything else then press enter.
6. It will ask you for user name and password by default "admin" and password is " password "
7. Once you click ok it will open netgear setting page
8. On the left side you can see wireless setting which is under "setup" then click on that option
9. On the middle of the screen you can scroll down that page at the bottom you can see your security key or passphrase.
10. Or you can type new password on the same screen and apply those settings
11. Now try again to connect your device wirelessly enter you existing password or new password which you have setup.
12. Make sure one thing more on the left hand side you have option called "Router Status"
13 Once you click on that at the middle of the screen show you router status and you can find the option called "internet port"
14. We are getting ip under internet port
15. If we re getting ip address then you can simply try to connect wirelessly otherwise please run setup wizard to configure your router. you should getting ip under internet port.
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Aug 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
My screen
i am having the same problem with my phone, but it will stay black for long periods of time. i wish i had never bought it.
Sep 03, 2007 | Motorola Mobility RAZR V3
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
My tv is on but the screen is black except for spuratic flashes
i have the same problem, yesterday my tv stops, today I was on the internet trying to find something , I find a Phone number so you can call and explain what is your problem . It works. 1 800 726-4405 or a web page akaiusa.com try it.
Jul 05, 2007 | iLO V27DMBX Television
Palm Treo 755p Smartphone Logo
101 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
