Question about Maytag M6Q10F2A Air Conditioner
MY Unit will not Shut off Unless I unplug it
It cointinues to make a loud noise as if was running, and no are comes out (this is in off mode). When I turn it on, that when the air turn on. also, is there a way to find a manual for it? Thanks.
J
  • Anonymous Sep 02, 2008
    WIL NOT SHUT OFF MAKES LOUD NOISY
    WILL NOT SHUT OFF UNLESS IT UNPLUGGED
You ****
Posted on Sep 10, 2008
  • 40 Answers
Google the name and model number. Ask for manuals
Posted on Jun 20, 2008
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Vibration when heat only is on inside and out
Is it noisy always when running in heat or only for intermittant periods? Depending on where you live every 45-90 minutes of run time the heat pump goes into a cycle called defrost. The fan on the outdoor unit will shut off. the compressor will continue to run but in actually cool mode. this heats the outdoor coil and allows any frost or ice that is built up on the outdoor coil to melt. The compressor can get pretty loud in this mode and you may actually see steam coming off of the unit. This is normal. However if it is noisy all of time in heat check/clean your coils. If this doesn't remedy it have your refrigerant charge checked by a NATE certified Service Technician. Good luck.
Nov 22, 2008 | Goodman CLQ36AR49 Air Conditioner
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
May 08, 2008 | Canon S 750 InkJet Printer
Sub makes loud noise when car is shut off
Does it make noise if the RCAs are unplugged? If not, the RCA shield on your head unit may be burned open.
If the amplifier is set to signal sense, it will take longer for the power light to go off.
Nov 13, 2007 | Jl Audio 250/1 Car Audio Amplifier
Maytag M6Q10F2A Air Conditioner Logo
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
