Question about Cozy (W352E) Heater
Older floor furnace pilot light wont stay lit even after replacing thermo couple
    Genius:
  • 1,015 Answers
I would first check to see if pilot flame is burning clean and strong enough.It should have about 1&1/2 inch flame with slight yellow on tip. Most of flame should be bright blue. It's possible that pilot orifice and/or gas feed tube are dirty. If you feel comfortable with doing this it may help.Sometimes they can be hard to get to but the main thing I would caution you on is if you disconnect pilot gas line to be very careful when you are threading fitting back into gas valve. Fitting is brass and gas valve is aluminium so its easy to cross thread and cause leaks. Also if this is a millivolt system it will have what is called a basso and if its bad it can cause this problem.Normally if it's a millivolt system there will be no outside source of power, no blower or fan.Hope this helps you. Thanks
Posted on Nov 03, 2010
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
How do I install a thermocouple part #322391 in a Williams gas furnace
Gas furnace will not light. Thermocouple test with the ...
? 4:03
https://www.youtube.com/watch?v=suen7QlJl4o
May 12, 2012 - Uploaded by grayfurnaceman
I show how to bench test a thermocouple for a gas furnace using a multimeter. This video is part of the pilot gas furnace playlist.... Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace - Duration: ...
Oct 29, 2015 | Williams Heating & Cooling
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Feb 21, 2015 | Rinnai Heating & Cooling
My Furnace pilot light will not stay lit
chances are the thermo couple which is a copper wire that comes out of the controller is most likely broken check on that and replacement easy enough to replace and not too costly.
Dec 25, 2014 | Heating & Cooling
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light on Tempstar furnace wont stay lit. replaced thermo-couple and it still wont stay lit. what next???
Do you have a good pilot flame? Is it wrapping around the thermocouple good? You may need a new pilot orifice.
Mar 07, 2014 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
I have a older Miller furnace(1989)the pilot will stay lit
Replace the thermocouple.
Try this, do you have a butaine stick lighter? Try to heat the thermocouple with it ... see if you can get the main burner to come on. If not - definitely, replace the thermocouple.
Thanks for your question.
Jan 04, 2010 | Heating & Cooling
Cozy (W352E) Heater Logo
361 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
