Question about ID Tech IDMB-334112B Magnetic Card Reader
I cant rewrite any cards - ID Tech IDMB-334112B Magnetic Card Reader
  • 7,733 Answers
How can I verify the reader works?
For a keyboard wedge interface or USB/keyboard emulation interface reader: Get into any simple text editor - Notepad is recommended in Windows environment (locate it through Start/All programs/Accessories/Notepad). For a dual track reader, swipe a credit card, the reader should beep twice & there will be two lines of data show up in a Maximized Notepad window. (1 st line starts with % and 2 nd line starts with ';' both lines should end with the '?' for readers with the default output configuration). For a triple track reader, swipe a driver license card, which has a magnetic strip with all 3 tracks encoded. The reader should sound 3 beeps, and 3 lines of data will be displayed in Notepad window
For a RS232 serial, USB/RS232 emulation, USB/CDC interface reader:
Setup a HyperTerminal test session (Refer to General FAQ for detailed instruction). For a dual track reader, swipe a credit card through, the reader should beep twice & there will be two lines of the data show up in a Maximized HyperTerminal window. (1 st line starts with % and 2 nd line starts with ';' both lines should end with the ';' for readers with the default output configuration). For a triple track reader, swipe a driver license card, which has a magnetic strip with all 3 track data encoded on it. The reader should sound 3 beeps, and 3 lines of data is displayed on the Hyper Terminal Screen
Note:
1) If the reader doesn't beep when passing a magnetic card through it, please check and make sure the magnetic stripe is facing the correct side of the slot so that the stripe is contacting the reading head.
2) If the reader beeps correctly, but no data is shown in Notepad, please check to see if the correct software is being used for testing. If the answer is 'Yes' check the cable connection and testing software's configuration settings.
3) If the card is read and some of the card data displayed, please reset the reader & re-test.
4) If the reader is verified working, but it just does not work with your application software, please contact the software side for data format expected by the software side and re-configure the reader's output accordingly.
For more go to LINK.
Posted on Nov 03, 2010
  • 1,679 Answers
There is switch on the edge of the card to lock the card from read/write. Check if it locked and unlock.
This switch prevents anyone from trying to write/erase your data in the memory card.
Hope this is helpful
Remove rewrite protection from card
SD and SDHC cards as well as microSD adapters have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 16, 2012 | SanDisk 2GB microSD Memory Card
In my psp 2000 when i put the battery in green light flashes automatically but the screen does not work and when i turn it on nothing happens that green flash remains the same please help me somebody its...
You have to reprogram your console. First, create a recovery memory card using Pandora, then, you need an Pandora cracked battery to can rewrite the SW.
Jun 01, 2011 | Video Game Consoles & Games
Can these disk be re write or erased? Please send me an email via affordableshutters@yahoo.com Corrington Maycock
Welcome to Fixya. The CD is not a Rewritable disk you can only burn once. If you need a DVD or CD that can be rewrite or erase look for DVD-RW or CD-RW.
Thanks for using Fixya
Mar 14, 2011 | Philips (DVDR1S02/771) (100 Pack)...
Brought 5 maxell 1.2x rewritable 4.7 gb data dvd-rw tried to record a film keeps saying no disk what am i doing wrong? kind regards ken moore
if the other 4 dvds are still wrapped take it back (in exchange for 4x 4.7gb dvd-rw)...you picked up 1.2x your player maybe looking for higher speed..these recorders are very sensitive for the type of dvds it use..(i can only use maxell /panasonic + dynex (online))..cant use some of those on sale ones.....my recorder wont just eject it it rejects,,,,
hope this is your case, feel free to rate the help
Jun 16, 2010 | Maxell MAX635114 Rewritable Single-Sided...
Cd burning in linux
Please go to ***softpedia******** and download a burning software for your linux OS ...
May 13, 2009 | Maxell Compact Disc Rewritable 4-10X Speed...
I have The problem about Janome Memory craft 9000
Do you have a Magic Box or Amazing Box? The only way I know how to rewrite your card is to insert it in the Box and it will ask you if you want to erase the card. I have the same machine and I believe your cards that you buy with designs already on them are non erasable. You have to buy a blank card to put your own designs on them.
Jan 16, 2009 | Janome Memory Craft 9000 Computerized...
Cant Play Blu Ray on my System
You say you "believe" your card is HD compliant. Maybe it is not. Check Geforce website to find out for sure. I assume, like televisions, monitors must also be HD compliant. But I don't know this for a fact. I am interested in getting that information.
Dec 27, 2008 | Computers & Internet
Earsing a disk so i can copy over it how do i do this
U NEED CD-RW DISC TO ERASE AND REWRITE IF THE DISC READS CD-R IT WON'T REWRITE, U CAN NORMALLY JUST DELETE THE FILE OR REFORMAT THE DISK WITH THE WINDOWS FORMAT FUNCTION, USE UR HELP AND SUPPORT FOR HOW TO ACCESS THIS FEATURE.DEPENDING ON HOW U R TRYING TO ADD SOME APPLICATION ADD INFORMATION IN OPEN /CLOSE SESSION WHICH MEANS AFTER THE APPLICATION CLOSES ONLY IT CAN ACCESS THE INFORMATION
Aug 10, 2008 | KHypermedia (2826000000) 100 Pack 52x CD-R...
Burning
could you provide more info? the model number of the drive for exmaple. are you sure your using rewriteable DVD's? sorry to point out the obvious but id kick myself if i didnt check. Also you can goto the manufactuers website and if there is a firmware upgrade for your model of DVD writer.
Sep 05, 2007 | NEC ND-2500A DVD±RW Burner
ID Tech IDMB-334112B Magnetic Card Reader Logo
270 people viewed this question
Top ID Tech Televison & Video Experts
Are you an ID Tech Televison and Video Expert? Answer questions, earn points and help others
