GHT MP3 PLAYER/D-2000
When I try to turn it on , it shows that it's locked (with pictures of music notes), how can I release this locked ???
There is a button on the side of the player that unlocks it slide it to the unlocked position
Posted on Aug 24, 2008
You have a technic problem
Posted on Jun 13, 2008
Deleting music off the mp3
Hi bethutchins..
Try this method to remove your files/pictures
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me
Bud
Oct 13, 2012 | Coby MP-610 MP3 Player
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
My Mp3 player is frozen on a file it says it's chargeing when its not
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa m250 MP3 Player
Lost all my music and i want it back :(
Try this method to see if the music is still on your player.
If you want to delete any music/files/pictures then do the following:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 04, 2009 | Apple iPod classic MP3 Player
There is phantom space taking up room on my mp3 player
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Nov 29, 2009 | Audio Players & Recorders
MP3 player GHT D2000 appears locked
hi shreejit here try to reformat the mp3 player so the code will be unlocked and u can use your mp3 player in a normal state
May 31, 2009 | Audio Players & Recorders
Videos wont show up on the mp3 player even though they have been downloaded sucessful.
what you have is a mp4 not a mp3. mp4 plays videos, music and shows pictures. mp3 only play music.
change the video format
try .mp4
May 19, 2009 | Innovage Shift3 MP3 Player
Why would my philps lock up and wont release the unlock at times.
There is a hold/lock switch on the player - you need to unlock it. Refer to your user's manual in order to see a picture of where this hold/lock switch is.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips GOGEAR SA6045 MP3 Player
156 people viewed this question
 Grubhead
Grubhead
