Question about Refrigerators
I have a GE BSS25JSRFSS. Cannot get water dispenser to work. Ice maker working fine. Changed the water filter. I have seen on another site that soemtimes the line can freeze. Cannot locate any hints how to thaw that line. Can't see where the line runs or immagine whre it may be frozen. Any suggestions would help.
  • 3 Answers
The easiest way would be to unplug it and let it thaw out. if after thawing out it doesnt work then you most likely have a bad water valve solenoid. rarely have I seen a line freeze though
Posted on Nov 03, 2010
  • dkaakd Jul 31, 2011
    The line needs to be warmed-up in a few placed. Take out the veg. crisper in the fridge and use a hair dryer to warm the water line behind it. Also, open the freezer, empty out the ice in the ice maker, warm the ice tray and cooling units above it. The take the hair dryer and spend about 10 minutes warming up the area on the inside door panel of the freezer. Especially behind the water dispenser. After that, give it about 10-15 min to defrost a bit. Once the water starts flowing, dispense about a quart or two so the water moves though the lines.
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Ice maker tray not filling with water.
Changed the filter, now it works fine. I'd still like to find a way to bypass the filter. My fridge is only 2 yrs. old, but I'm sure it will have plenty of life left after these filters become unavailable.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
