SOURCE: lexus ls 430 2001
are they not the same as the other cars where you will press a clip at the bottom of one of the post and you can slide out the headrest?
tnx 4 using fixya,
drcool
SOURCE: 2004 Lexus Ls 430 Low tire
You need to check your tires for the proper pressure. If all are inflated to the tire specs, then disconnect both terminals from your battery, wait 5 minutes and reconnect. Should do the trick. Please don't forget to rate! Thanks.
SOURCE: what procedures do I take when removing and
Im not sure where the lexus starter is located but here is your standard steps.
Hope this helps
