Question about Indesit W 123 Front Load Washer
Each time i turn on my washing machine, it cuts off all the power by turning the main fuse off. When i turn the fuse back on, the washing machine starts for 3 seconds and then cuts off the power again. What is the problem and what should i do to get it working again?
  • 320 Answers
Your machine has a short circuit problem. It must be repaired by a qualified technician.
Posted on Nov 03, 2010
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
My washer will not turn on
Power cut may have blown fuse . If not check mains filter. If that's ok then mother board may be damaged
Aug 08, 2014 | LG WT5101H Top Load Washer
Hotpoint aquarius wdl540
if the washer has water in, disconnect the waste hose and put it in a bucket and drain out manually, once the water level is low enough the door lock should release without the appliance being plugged in
Apr 04, 2014 | Washing Machines
I turn on the power, set the mode, press start and it cuts out in a couple of seconds
MACHINE IS NEW MODEL,, ITS PROBLEM WITH MAIN POWER CONTROL BOX,, KINDLY CALL SERVICE TEAM....
Dec 15, 2013 | LG Washing Machines
No power to my Indesit Washing Machine.
PCB has suffered a catastrophic failure due to the power cut, it will need to be replaced. if you have a power cut in the future always turn off your appliances, as the voltage can exceed the appliance recommended voltage. only leave a light on as lights can take the over voltage unless they are led type, you can but power drop sockets that when power is off it turns of the socket off so no power goes thought to the appliance.
Feb 01, 2018 | Indesit W 123 Front Load Washer
Hi, wh had a power cut and now when i turn our washing machine on the power light and 2 other lights are flashing. I have turned it off and took the plug out. When all back on all the lights are on and...
sounds like you may need a new board, some power surges can damage electronics in major appliances a surge protector at the main box may prevent future problems. with this one i would unplug for five minutes then plug back in if problem persists then your cooked need new board.
Aug 17, 2009 | Indesit Washing Machines
Trying to locate fuse in washing machine
if it bows the mains then dont try it again!
get it checked out ASAP!
Jul 26, 2009 | Washing Machines
Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
Indesit W 123 Front Load Washer Logo
128 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
