Question about Toshiba Satellite A100-S8111TD Notebook
Help with Toshiba Satellite A100- TA7
A few days ago, all the desktop icons and start button disappeared from my laptop.....so I formatted my computer with the recovery disk and now I lost all my files.. The files, especially my class notes are really important for me.. Is there any way I can recover my files?
  • kwabena maxwell Jun 15, 2008
    New Friend:
    Problem Solver:
  • 15 Answers
You should always remember to back up everything important on another drive before the formatting.
But, now, in order to get back all your files, one of the best ways for you is to try a PC data recovery freeware that could help you easily retrieve these deleted files back:
http://www.freeware-fix.blogspot.com/2013/02/data-recovery-for-pc.html
This freeware has specially offered a "Format Recovery" option for the user to process the different format data recovery problems. So, it could be a great shot for you!
Posted on Aug 22, 2013
  • 3,940 Answers
The honest answer is that you MAY be able to recover the files, and it is mostly a matter of how much is it worth to you to try to get the files recovered.
Depending on how Windows was reinstalled (Clean install, Repair install, Parallel install) and were the files were located in the file structure will determine most of how hard it would be to recover the files.
For example, if the files were in your MY DOCUMENTS folder, and you reinstalled using the same computer and user names, then that file is over written. If you had installed Windows in a different folder on the hard drive and used a different user name, then those files would be in a different folder and you'd just have to search the hard drive to find them. From what you described, your files will not be accessible without the specialized tools of a data recovery expert.
Data recovery is generally and expensive proposition that requires extensive skill and some pretty
software to recover the files. Most people, once they are given an estimate of the cost, decide that the data wasn't all that important.
Some companies you can contact:
http://www.drivesavers.com
http://www.ontrackdatarecovery.com/
http://www.salvagedata.com/
http://www.iomegadatarecovery.com/
http://www.actionfront.com/
Posted on Jun 13, 2008
I have problum dvd writer
is the DVD writer the original unit in the notebook ? if not usre, refer to the manual -- if you dont have manual, go here (it will cost a little )
http://user-guides.co.uk/cddownload/Toshiba/ToshibaSatellite/Toshiba-Satellite-Pro-A100-TOSHIBA-Satellite-A100-Satellite-Pro-A100-161676.html
before you format, try replacing the DVD writer another unit similar
buy recovery CDs here
http://restore-disk.com/restoredisks/Toshiba/ToshibaSatellite/Toshiba-Satellite-A100-S8111TD-with-Intel-Celeron-Processors-XP-Driver-421349.html
i would restore the notebook to factory settings -- this is the best option in getting the computer back to the way it worked originally going to the factory settings management portion in the system and or use your recovery CDs to format and re isntall everything
Oct 15, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite a100-ta7 system unit shuts off before boot .
try upgrading the memory module the observe for a quite sometime. if still, reformat your laptop by using the recovery disk.
Jun 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do set up my microphone
Hi, from the Desktop, Click on the "Start button" to open the Search (window), next Type: microphone; the "Microphone Configure" Icon appear, setup the microphone. "Rating the solution is appreciated if it helped, thanks"
Mar 14, 2010 | Toshiba Satellite A100-S8111TD Notebook
Motherboard problem
Most likely the contact point of your battery pins are not snug enough. If under warranty, then replace the battery, else give it to a technician to do this clean-up operation. Try another battery too to crosscheck!.........sodeep
Mar 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba Satellite A100, which needs formating.
Restart and use F12 and it will boot from the disk.
Please rate this sulution when you can.
Jan 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
SOUND DRIVER
hi i have toshiba SATELLITE PRO A 120 LAPTOP MODEL NO PTA 83L-08L02L .after formating i lost sound now not any drivers is compatible for my computer .and i dont have recovery cd also please help
Sep 08, 2008 | Toshiba Satellite A100-S8111TD Notebook
MY COMPUTER IS A SATELLITE A215-S7408. MY PRINT WAS NOT FEEDING THE PAPER- SO I REACHED OVER THE LAPTOP TO TURN OFF THE PRINTER,AND MY BELLY MASHED A LOT OF KEYS ON THE COMPUTER. WHEN SAT DOWN TO RESUME...
you turned the display be a function button, but without knowing which, use system restore instead, click start>programmes>accesories>system tools>system restore and choose a restore date a few days ago
Aug 29, 2008 | Toshiba Computers & Internet
Unable to format my Laptop
set the bios to boot from dvd and you will be away
Jul 06, 2008 | Toshiba Satellite A100-S8111TD Notebook
Desktop icons disappear when logging on
sounds like you have the display settings for power save set on short cycle.
start button on bottom left click once(leftclick)
open control panel
do to display(Windows xp) double click
go to settings
click on power settings
change to a longer time table
If you like we can do this with our screen sharing service. see my email in my profile for connecting with our team.
Feb 17, 2008 | Toshiba Satellite A105 Notebook
Desktop Icons
Right click your desktop, click "Arrange icons by" then check show desktop icons.
That should do it..
Jan 22, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
