Question about GE Microwave Ovens
Was using microwave to pop quite a few bags of pop corn to feed birds. Microwave is hot to the top to the touch. lights on the front of the microwave are not lit up, no power. WALL RECEPTCALE is active.
    Genius:
  • 1,036 Answers
Plug fuse may have blown. Replace that first or test.
Internal temperature trip may have cut out (if present)
Microwave generator (magnatron) may have failed.
Internal power supply may have failed due to moisture.
Very likely this machine is dead.
Save energy - and cash, by feeding birds stale bread and raw seed and corn.
Hopefully the next microwave oven will last longer.
The cost of repair may be more than the cost of replacement. Ask your nearest repair shop how much to replace the microwave unit, and check the power supply.
Sorry I can't offer a quick fix for you.
Posted on Jun 13, 2008
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
GE Profile Spacemaker XL1800 Magnetron failed and replaced but now it heats too much for one touch sensor buttons...Basically the unit stopped heating. I replaced the Magnetron. I test by trying to pop...
You probably just have a bad humidity sensor (aka gas sensor).Also be sure the internal cooling fan is running. That's critical.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
To access and replace the sensor, you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can find handy exploded views and order parts by model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 21, 2011 | GE XL1800 1100 Watts Microwave Oven
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
I have an Emerson Microwave 700W W7300W. I was popping a bag of corn and the plate inside broke completely in half.
measure the glass plate diameter , you can buy them on Ebay , but since they make these fast and cheap, the glass plate might of had a flaw in side like Toyota ......................
Mar 14, 2010 | Emerson Microwave Ovens
What is the best microwave popcorn for my dacor microwave we just got it and i thought i would try some microwave popcorn it did not work very well the turntable just keep turning but the popcorn did not...
Put any microwave popcorn on a up side down dish so it is about in the middle of the oven. Make sure you follow the "this side up" instruction on the bag.
I am a microwave pop corn wizzard.
Jan 17, 2010 | Dacor DCM24 Convection/Microwave Oven
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Can't pop popcorn well
It's 850 Watts, 0.9 cu ft.
That's enough for popcorn, but a magnetron does lose power once it starts to age.
The figure I've heard is an average life expectancy of 2000 hours for a magnetron.
Two "Band-Aid" suggestions for better exposure and more even heating:
1. Place the popcorn bag on top of an upside-down paper plate.
2. Place the bag off-center instead of dead center. Placing food in the center of the turntable is not as efficient as placing it off-center.
Dec 12, 2008 | Welbilt MR95TW Microwave Oven
Microwave will not function properly.
The cavity thermal fuse may have failed. It is located on the top of the cavity.
Jun 13, 2008 | Microwave Ovens
Microwave
That's probably because there's still steam (humidity) in the cavity after the first bag is popped.
After the first bag pops, try wiping down the walls and ceiling and leaving the door open for a couple of minutes.
You might even blow or fan the air out of the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
121 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
