Question about HP DeskJet F4280 All In One Printer InkJet
HP Deskjet F4288 Cartridge Error.Display E appear on the panel, no print not even test page , ink is full , still level checker blinks
SOURCE: hp deskjet f4288 cartridge problem
my printer number is hp deskjet f4288 all in one my problem is my colour catridge haveing ink but but showning error in colour side please send me immediate a solution
Posted on Mar 12, 2010
Soulvisitor
  • 1113 Answers
SOURCE: Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Posted on Dec 12, 2008
SOURCE: dear sir my hp f4288 printer cartridge is not
hello sir pl how to insert and fix the cartrige in hp f 4288 printer..i cant fix the cartrige both also..
Posted on Jul 30, 2009
SOURCE: Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Posted on Apr 28, 2010
  • 1751 Answers
SOURCE: HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Posted on Nov 23, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
HP DeskJet F380 All-In-One Printer catridge problem
Try with another cartridge, If the same error, the printer head is bad.
Jul 04, 2012 | HP DeskJet F380 All-In-One Printer
Sir,I am having HP Deskjet F4288 All in one printer,which was purchased on 20 Aug 2008 from Nikshan Electronics,Kannur,Kerala.Now it is not working and showing E {error} indication and blinking the print...
Hi sir, I think that you are having issue with the regionalization of the printer. HP printer are programed with a certain ink cartridge for every country. Print a test page and you can see there the right region of your printer. Check this link to know the right ink for your printer. And don't use refilled ink, it might cause damage on your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01573152&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
tnx..
Apr 10, 2011 | HP Office Equipment & Supplies
I cant print anything frm hp f4288
hi
you have a bud refilling process
check here how to refill right fro black
http://www.youtube.com/watch?v=MPi2GqJg5QM
for color http://www.youtube.com/watch?v=C6-N-Pxmjxk
Mar 06, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet f4288 cartridge problem. the cartridge is not showing ink lable on panel
Apr 26, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet F4280 All In One Printer InkJet Logo
557 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
