Question about Kenmore 19001
My 1900 series embroidery machine is seperating the cotton layer of thread from the interior thread. I don't know qany other way to explain it
  • perkins11876 Nov 04, 2010
    I am not talking about when I embroidery, although it does the same thing then. I am talking about just regular sewing. Plain straight stitches. The top layer of covering on the thread, I suppose it is the cotton covering on the string of thread, is being pushed up the center shaft of thread and breaks after a few sticthes. I use quality thread, not cheap thread. I use the embroidery threads sold by Kenmore when I try to embrioidery and get the same results.
    New Friend:
Could you send a picture.
sound like tension. I could be bottom, tension to loose if it is coming to the top. Top tension if it is pulling on the bottom.
Posted on May 26, 2014
  • 22,483 Answers
Not sure here so iasked advice and she want to know is it one bobin of thread that is seperating or two bobbins of thread at once ?? then she can tell you the problem but she has gone on about cheap cotton from india ,if two bobbins it could be the tension is wrong on one of the bobbins
Posted on Nov 05, 2010
    Genius:
  • 1,456 Answers
Hello
Ensure that you have set the fabric properly on the machine.
Take the embroidery hoop and place the fabric into the hoop, securing the fabric and stabilizer with the metal clasp. Set these aside, and load the embroidery thread onto the sewing machine. Press the embroidery button on the machine; it is the second button from the top. The machine will set itself up for embroidery mode.
Attach the P foot that came with your machine, and then attach the embroidery hoops with fabric still inside the sewing machine. Turn the knob on the embroidery hoop to your right until you here it click in place.
Buy tear away or water soluble stabilizer for easy, mess-free designs.
Posted on Nov 03, 2010
Brother750e in-no is dowloaded photo transferred to stitches using foil thread or embroydery thread , top thread keeps breaking, I've changed the needle don't know what else to try . Please help
Metallic thread is often easier to break when sewing. Make sure the thread is not brittle and old; It may also require "Metallic Embroidery" needles that have a slightly larger needle groove and eye spaces. Also, make sure your thread does not have additional tension on it when being fed from a vertical spool. allow the thread to flow horizontally off of the thread spool into the machine.Or place the spool bottom down on the table next to the machine and let the machine pull it up and over through the machine which needs to be very properly threaded.
Cheers,
Embroidery Services
San Diego, CA
Jul 09, 2016 | Brother Sewing Machines
Futura repair
When you thread the top thread, ALWAYS RAISE the presser foot. This allows the thread to seat completely in the tension disk, otherwise you end up with bird nests or thread nests under the fabric.
Jan 04, 2018 | Sewing Machines
I'm working with 2 layers of cotton for most of a project but part of it is 2 layers of terry cloth in addition to the cotton and I keep running into trouble with my bottom thread. I'm very new to sewing,...
well, Rose, i could make a few suggestions- but, my wife is the guru of sewing machines- will turn her loose on it later- what make & model? sounds heavy duty. later.
Nov 03, 2013 | Euro-Pro Sewing Machines
Im trying to sew letters on thin fabric and lace. I think the grip is to ruff for the fabric. how do i fix this?
you will need to have stabiliser behind the fabric to give it stability for any type of machine embroidery.
Look for a product called "stitch and tear" or "solvy" which washes away in water after you've completed the stitching.
Also, consider using machine embroidery thread for this task, its silky and gives a lovely sheen.
I've always used an embroidery hoop to hold the layers all together for monogramming so things don't slip.
I'd suggest you google "machine embroidery" or try www.sewing.about.com and see if there are other machine embroidery tips there.
Apr 05, 2011 | Sewing Machines
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
Stitching trouble
Here is a trouble shooting chart - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1238&CS_Catalog=Elprojects
I would start with cleaning (see maintenance section of the user's manual).
This has to be done more often with sewing/embroidery machines that have a drop-in bobbin.
Be sure to use bobbin thread for machine embroidery.
Always thread the machine with the presser foot up. This will insure the thread is seating into the tension control.
Apr 30, 2010 | Brother Disney PE-180D Computerized Sewing...
Problem with Brother Quattro
This is an Embroidery machine. Use a thicker thread if only sewing. If doing embroidery, check your hoop for proper size, and make it tight holding the material.
Jan 03, 2018 | Brother SE-270D Computerized Sewing...
Threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
May 22, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
