Question about Refrigerators
Water dispenser keeps flowing when water source is turned on
Comment by shigemite, posted on Jun 06, 2008 kenmore model 106.51062100 refrigerator... changed water valve twice.  Unplugged fridge to see if water valve was defective; upon turning water supply on, water dispensed continuously; thus got another new valve installed since previous valve wouldn't stop water flow.  Same problem again with water continuously dispensing when new valve was installed...again, shut off water and no filtered water, nor ice, until problem fixed.  Going on three weeks, just about to call repairman, unless fixya can fix it.
thanks.
shigemite
Comment by shigemite, posted on Jun 06, 2008 please see comment posted 6/6/08...thanks. Comment by shigemite, posted on Jun 06, 2008 sorry...which one would be the drain hose?
shigemite
Comment by shigemite, posted on Jun 09, 2008 could it be an electrical problem?  i.e. micro switch, control board, etc. Comment by shigemite, posted on Jun 09, 2008 could it be an electrical problem?  i.e. micro switch, actuator switch, dispenser control board, etc.
    Genius:
  • 3,422 Answers
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Posted on Jun 13, 2008
Why is my water dispenser flowing slow
Good Afternoon Friend,
I understand that the water dispenser is dispensing water slowly, from your Frigidaire refrigerator. I suggest changing the water filter. If that does not work, check the lines going into your refrigerator, to make sure they are not kinked. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Frigidaire Refrigerators
Enmore refrigerator model 795.71013.010 ice maker
michael masters is not giving you the proper info. i realize this is from a few years ago but i have to call out a dumb comment when i see it. he told you how to check a whirlpool ice make rand not an lg style ice maker. that you have with an 795 source refrigerator. sorry the he gave you the wrong info. if after 4 years you are still needing help, please respond and i will help you.
Mar 13, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
NO WATER FLOW TO ICE MAKER
Check water filter or bends in water line start at water source
Mar 29, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side/Side Frig Model 57765791 Water dispenser quit.
  1. listen for click of the switch when you try and get water,
  2. make sure you have water to valve on back of refrigerator, turn off water and take line loose place in a bucket and turn water on, you should have a strong flow of water, it is common for people to have a self piercing saddle valve on the water line. these valves plug easily
Nov 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser problems
You need to replace the filter...exact thing happened to me!!
Jul 10, 2017 | Kenmore Refrigerators
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
