My foldders file extension got changed automatically
In my F drive,My foldder's file extension got changed automatically to hsæ\d▒┴.*zT and lots other it contain some importent things how could i get it resolved plz help me hidbhsdfaldfuhsdg
  • 24 Answers
U can chage the extension thorough right click on it and click on properties of it then change file openwith option properly.
Posted on Jun 13, 2008
How can I reproduce video with extension tmp
If you go to files and folders and 'show extensions for known file types' you can edit the title including the extension.
However I can't understand why you want to use 'tmp' which is a temporary file and is liable to be cleaned out by any hard drive utility program
Feb 15, 2015 | RCA (DTA800B1) Video Converter
Intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
Oct 29, 2011 | Ctm HS-2800 Power Wheelchair
I'm unable to rename any file in win XP,a message appears "If you change a file name extension,the file may become unusable" Plz help
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Mar 13, 2011 | Microsoft Windows XP Professional
Avery backup labels changed to .zdl file extensions when saved to miscellaneous folder on pc
looks like a file association issue in the registry. try updating your windows registry to repair any outdated file extension association.you can either manually do it, or use a software to automatically do it for you. if unsure what to do, you can refer to this file extension avery guide.
Sep 28, 2010 | Avery Design Pro 5.0 for PC
I scan memory card with quick h antivirus and all the files in the card automatically showing hidden and even not showing on computer in hidden form too..i check it with x plore, it shows all files but...
This is a common problem. Some antiviruses take the data as a threat/virus, and place them in a seperate hidden folder and changes their extensions (extensions are the file types e.g MP3, JPEG, etc) so that they are no longer accessible. I'd advise you to connect it with your computer. Then go to the TOOLS tab in your upper part of the computer window. Select Folder Options and choose "SHOW HIDDEN FILES" Im sure you'll be able to see those files. Unhide them by changing their PROPERTIES, and restore their extensions simply by typing in the previos extension using the RENAME option of your computer. I hpe this solves your problem If not, you may clarify your complaint and mail me at : streetstyles@live.com
Regards. Hamza Naveed Malik
Sep 02, 2010 | SanDisk 2GB microSD Memory Card
I cannot find a whole batch of jpeg files on my hard drive. I suspect that somehow they have invalid file extensions so are hidden from me. Is there any method I can use to reveal these disguised files? ...
open My Computer. Go to Tools -> Folder Options.
Go to View tab.
Select "Show hidden files and folders" and un-tick "Hide protected system files (Recommended)". Accept the warning message, and click OK to accept the changes.
Now ALL files are revealed! If your missing files are there - you'll be able to see them, if you can't - they're probably gone!
If you suspect the extensions had changed, search for a filename of any file from the missing ones, and make sure to tick "Search in hidden files and folders" under "More advanced options". Once you find one file, search for it's extension to find the rest (search for "*.???" - without the inverted commas, change ??? with the extension you've found).
Cheers,
Pelu.
Mar 09, 2010 | Computers & Internet
I get a black screen on a ZT System PC desktop? How do I get it to boot up?
i think your system leave the hard disk. change the power pin of your drive. then again start system.
Jan 26, 2010 | ZT Group Cisnet PC Desktop
I had a cad drawing and I was messing around with it and lost it tried recover and can't recover it. I had someone resend it to me and every time I get it it changes to a file I can't open it is white page...
Most CAD programs such as AutoCad have a history of recently opened files. In AutoCad go to TOOLS/ OPTIONS/ FILES/ Automatic Save location. There you should find a file with the same name but a different file extension such as .BAK (AutoCad back-up) You can set AutoCad to automatically save to any time period, such as every 15 minutes.
Make a copy of this .BAK file so you keep that unchanged, Then change the file extension of the copied .BAK file to .DWG. Then you should be able to open this file. A file with an extension containing the $ symbol needs to be recovered using the programs recovery tool, in FILE/ DRAWING UTILITES/ RECOVER
If you're using a different CAD program look for this backup file wherever the programs Autosave files are set to be stored.
One other possiblity is the file extesnsion is set by your computer to open with another program for some reason. Right click and hit "open with"
Let me know if this helps
Jan 07, 2009 | Computers & Internet
Mapi32.dll file ismissing or wrong verion when italling office (outlook) on windowsXP pro
i read somewhere:Try renaming the MSMAPI32.DLL to MSMAPI32.XXX. Then try starting Outlook.
> File is at \Program Files\Common Files\System\MSMAPI\1033 for english
> systems
please let me know if it helped..
Oct 31, 2008 | ZT Group ZT Reliant 823XI38 Desktop PC
Can you still open it? Are you talking about a file extension, or a folder name? Folders themselves don't have extensions...
Maybe you should just make a copy of it, then try to rename the folder name/file extension to whatever it was before, then try to open it.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
