Question about Maytag Refrigerators
WE HAVE A MAYTAG REFRIGERATOR, SIDE BY SIDE. I JUST REPLACED THE WATER FILTER FOR THE COLD WATER AND NOW CANNOT GET THE WATER TO COME THROUGH. DO I HAVE TO DO SOMETHING DIFFERENT TO MAKE THIS HAPPEN. WHEN I PUSH ON THE WATER RELEASE IN THE DOOR, IT JUST "BUZZEZ".....I HELD IT OPEN FOR UP TO TWO MINUTES AND NOTHING HAPPENS. WHAT SHOULD I DO.
  • 4,070 Answers
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. .
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad.
Posted on Nov 03, 2010
Testimonial: "YOU ANALYZED THE PROBLEM CORRECTLY AND IT IS SOLVED WITH YOUR SOLUTION. MANY THANKS."
Slow ice production on maytag fridge
Replace the water filter. If you replaced your water filter, depending on the fridge, they have two filter models. One is a fast fill filter (has less media and takes out less contaminants). The other filter is a better filter and takes out more contaminants (because it has more media) and will slow down the water pressure.
Feb 03, 2013 | Maytag MSD2756G Side by Side Refrigerator
Side by side Maytag frig.dispenser water is slow. model MZD2665HEB I changed water filter .water flow is slower than normal.
When a water filter is replaced alot of air gets compressed in the plumbing and the filter which will cause a temporary reduction in the flow rate until the air is bled out through normal use.
Jan 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is not as cold as it was and freezer stopped making ice, i know the water filter needs to be replaced. i removed it and a new one is on order
filter not the problem ck for ice in back of freezer sounds like the cold coil is blocked with ice . it may have a defrost problem .. mm
Oct 17, 2010 | Maytag MZD2766GES Side by Side...
What water filter does it use?
hello there
Item #
1446373 Price
$41.65 In Stock?
Yes Maytag/Amana/Jenn-Air PuriClean II Refrigerator Water Filter - The PuriClean II water filter is manufacturer part number UKF8001AXX. It is a high-quality carbon filter that reduces contaminants such as lead, cysts, pesticides, herbicides and much more. Replace annually or when the filter light is on.e643401.jpg
Jul 27, 2010 | Maytag MSD2656G Side by Side Refrigerator
My refrigerator water dispener is dispensing jelly like stuff !
run it until the water comes out clear and replace the filter trice.
Mar 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Trying to repair water dispensor
Check/clean/replace dual water inlet valve/solenoid.
Nov 30, 2008 | Maytag MZD2766GES Side by Side...
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Whirlpool ED5VHGXMB10 side by side
I had the same problem, and had to replace the temp regulator. It is located on the refrigerator side, by the water filter. It took me 15 to 20 minutes to replace it.
Sep 09, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
208 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
