Question about KitchenAid KERC607 Electric Kitchen Range
I have no power to my range. I accidently touched the side and center of the oven light bulb socket while trying to get the broken off light bulb base out ot the socket without unpluging. The inline fuse is still good but no power to anything else. Could it be that the microcomputer be fryed? How can I check to see.
I have exactly same issue. No power to my KitchenAid (Whirlpool) YKESC307BW6. I tried to bend the oven light socket with a screwdriver (with power on) like a dufus. I already had an issue with control panel relays for ovn elements fried. I plan to get a new control panel but need to be sure its the conrol panel. Did you find the issue and was it control panel replacement? Thanks
Posted on Dec 08, 2010
  • souche911
    souche911 Feb 21, 2012
    hey,
    same problem for me, did anyone found a solution ???
    everyone do the same .. best tips ever : you have to repairit ? first thing to do unplug it !!
    you think it's repaired .. last thing to do ... plug it !
    hope to find an answer soon !!
Frigidaire Gas Range FFGF3053LSJ - oven light bulb tests OK but does not go on when oven door is opened
Make sure there is power present at the socket.
If not then the wire must have bad connector some where between the socket to the switch or may be the switch itself is defect.
If yes, there is power at the socket then make sure the center touch the end of the bulb.
Good luck
Mai
Aug 15, 2018 | Frigidaire Kitchen Ranges
How do I change the oven light in my range?
the bulb is probably broken in side the threaded end, un plug stove try to get glass part out, use needle nose pliers to unscrew socket part out, try not to cut yourself.
Jan 03, 2015 | Ovens
Replace the light bulb in the oven
Hello Carolyn, Stuck oven bulbs can be a bear to get out. One option is to access the back of the range and remove the panel and have someone hold the socket while twisting the bulb. But, There are other ways to try first.
Turn off the power to the range. Then using a silicone spray with a long application spray tube, ( most cans have it ) shoot a little silicone lubricant into the socket at the lamp base. wait 10 minutes and try again. It should come out.
Apr 08, 2014 | Kitchen Ranges
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Oven light won't come on
turn light switch off !! then take bulb out, then look inside socket u will see center little pin, with small flat head screwdriver gently pries out so that when new bulb goes in u r sure to make connection.
Oct 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Both bulbs on my 2002 S10 Blazer licence plate was burned out I replased them with new bulbs and they will not come on and I have checked the fuses what could be the problem?
you need to check for power and for ground at the lightbulb socket to determine which is not contributing to power the bulb(s). If the marker lights work at the rear then suspect a broken/melted light bulb socket, broken wire, or broken/rusted ground connection. Again, check at the light bulb socket for ground on one side (black wire) and 12V (brown wire) on the other. The light socket should have terminals that actually touch the light bulb; sometimes the sockets will melt not allowing a good connection. a cheap harbor freight multimeter (VOM) will help. Right and left side use separate fuses
Jan 13, 2012 | 2002 Chevrolet Blazer
Refrigerator light doesn't work. switch and bulb good.
If you have an elect. meter, you can tape the door switch closed, remove bulb, and touch your leads, one to the center tab on the socket and the other to the threaded portion of the socket, where the bulb screws in and you should have 120volts. If you are sure you have no power, unplug it and try and gently pull out the switch. This is the only thing between the light and main power below.The switch only connects to one of the 2 wires and a connector may have burned or come loose.If you have power to one side of the switch to ground, and its taped closed, and have no power coming out the other side, then you have a faulty switch.You can get a socket and or switch at your local appliance parts house. Just take the model, serial, name, and product # if there is one and they can match one up for you. I'm betting its the door switch.
sincerely, shastalaker7
Oct 30, 2009 | Refrigerators
Reposition light socket
It probably has to fit into a very narrow offset opening, like a tab into a cereal box. The hard part is getting the fixture up in and flat enough to slide it into position. You probably can't get to it from above. The ovens are normally sealed to prevent fires from going through.
Feb 22, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Nov 12, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
KitchenAid KERC607 Electric Kitchen Range Logo
156 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
